607 vs 617 RX??
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Futaba 2.4GHz 10CAG Integrated R6014HS Air Mode 2, 2.4ghz radio
Seller:  PropFlipper
Details:   $560.00   |  11/5/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> 607 vs 617 RX??
Page: [1]
Login
607 vs 617 RX?? - 12/20/2007 1:48 AM
sevans16
Score: 100
Last Login: 10/1/2009
Status: offline
What are the differences between these two 7ch RX's??
_____________________________
AMA# 737516
Hide Signatures
       Post #: 1
RE: 607 vs 617 RX?? - 12/20/2007 1:57 AM
DougV
Score: 100
Last Login: 11/8/2009
Status: offline
None!
http://2.4gigahertz.com/faq/faq-fasst-q926.html
Doug.
Hide Signatures
(in reply to sevans16)
       Post #: 2
RE: 607 vs 617 RX?? - 12/20/2007 2:00 AM
jonkoppisch
Score: 100
Status: offline
You can check compatibility at
http://2.4gigahertz.com/modules/modules-receivers.html
Confidence...The feeling you get before you fully understand the situation.
Hide Signatures
(in reply to DougV)
       Post #: 3
RE: 607 vs 617 RX?? - 1/11/2008 4:16 PM
AIRPLANENUTS
Score: 105
Last Login: 11/7/2009
Status: offline
Guys,
Apparently there is a difference. See page 3 of this thread @ RCGroups:
http://www.rcgroups.com/forums/showthread.php?t=772341
I tried to translate the German forum link with little success, but it seems as though there is a delay in response between left and right aileron channels 1 & 6 on the 607fs. 1.5 msec is what is posted.
Anyone who speaks German and English that can give a precise translation?
IF it is true, Futaba lied or was lied to and is passing on the lie, plain and simple. I have too much invested in the 607fs receivers to be misled by the mfr.
IF it is true, I'm going to consider JR and send the 607fs rx back to Tower.
"Futaba gets it right the first time."
Hide Signatures
(in reply to jonkoppisch)
       Post #: 4
RE: 607 vs 617 RX?? - 1/12/2008 2:36 AM
fritzthecat
Score: 105
Last Login: 11/6/2009
Status: offline
Summary:
The sequence of servo signals on the R607 is 1-2-3-4-5-6-7
The sequence of servo signals on the R617 is 1-6-2-3-4-5-7
The delay between left Aileron (1), right Aileron (6) is noticeably shorter with the R617. Especially heli-pilots may benefit from this change - improved three servo swashplate setup.
Fritz
Fritz the Cat
Send Money, Women and Guns!
Hide Signatures
(in reply to AIRPLANENUTS)
       Post #: 5
RE: 607 vs 617 RX?? - 1/12/2008 3:10 AM
bruce88123
Score: 100
Status: offline
So basically you are complaining because there is no operational difference other than it works better? No changes in where a given servo will be plugged in or if it will work, just improvements at a slightly higher cost. Costs generated most likely by more expensive parts replacing obsolete stuff. As we say in the airline: Interchangeable in form, fit and function.
3-D is for Monster Movies
Hide Signatures
(in reply to fritzthecat)
       Post #: 6
RE: 607 vs 617 RX?? - 1/12/2008 5:30 AM
sevans16
Score: 100
Status: offline
well, I am complaining because I was told there was no difference other than a minor component change by supplier(by Krysta). When there is an actual difference and it is nice to know so I can make an informed purchase of RX's in the future.
AMA# 737516
Hide Signatures
(in reply to bruce88123)
       Post #: 7
RE: 607 vs 617 RX?? - 1/12/2008 10:42 AM
AIRPLANENUTS
Score: 105
Status: offline
Ditto. I expect the truth the first time. I expect Futaba to be an above-board company honest in its dealings with its customers. Perhaps that is too much to ask.
Hide Signatures
       Post #: 8
RE: 607 vs 617 RX?? - 1/12/2008 4:47 PM
Bill Martins
Score: 100
Status: online
If I were able to assign ailerons to channels 1 and 2, with a 607 rec would that solve the delay issue?
I have (3) 607 recs and intend to use them on airplanes. With a 14mz TX a person can assign functions to whichever channel works for that set up.
I read the thread on RC Groups and I would be surprised if an average airplane pilot could tell the difference of 1.5 milliseconds. Maybe the heli guys can.
I don't see this as an issue for a large percentage of users.
Bill
Hide Signatures
       Post #: 9
RE: 607 vs 617 RX?? - 1/12/2008 5:10 PM
bruce88123
Score: 100
Status: offline
Most people don't even have a decent conception of how fast 1.5 milliseconds goes by. The average time it takes for a complete human blink is about 300 to 400 milliseconds or 3/10ths to 4/10ths of a second. Of course this is an average only and can differ from person to person. If you can truely detect 1.5 milliseconds it would qualify you as super-human.
Hide Signatures
(in reply to Bill Martins)
       Post #: 10
RE: 607 vs 617 RX?? - 1/18/2008 1:23 PM
JKos
Score: 100
Last Login: 6/22/2008
Status: offline
According to my logic analyzer, the sequence is actually 7-6-1-2-3-4-5 with a slight overlap between 7 and 6 and 6 and 1. I can post a graph tonight.
- John
< Message edited by JKos -- 1/18/2008 1:27 PM >
Hide Signatures
       Post #: 11
RE: 607 vs 617 RX?? - 1/29/2008 4:46 AM
sevans16
Score: 100
Status: offline
So which one is better?? Why is the 617 $5.00 more??
AMA# 737516
Hide Signatures
(in reply to JKos)
       Post #: 12
RE: 607 vs 617 RX?? - 1/29/2008 2:56 PM
bruce88123
Score: 100
Status: offline
The 617 is a tad better due to the change in sequence but as I said before barely noticeable. they alledgely had a problem getting some of the parts for the 607 so they updated to currently available production parts and made the "improvement". the 617 will be the only unit produced until if/when a new design is released. All servo plugs will be installed in the same sequence in the Rx.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
