HP Pavilion a21n Sound Card?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Off Topic Forum - Cars, Trucks, Buggies and more >> HP Pavilion a21n Sound Card?
Page: [1]
Login
HP Pavilion a21n Sound Card? - 12/20/2007 2:54:42 PM
Xtfreak
Status: offline
Where would I find the sounds card in this PC cause when I want to play music it says" sound card driver not installed or you dont have one" so I just want to see if I have one and where would I find the graphics card?[image][/image][image][/image]
_____________________________
BMX, Its not a passion...its a way of life - Peter Langman.
       Post #: 1
RE: HP Pavilion a21n Sound Card? - 12/20/2007 3:15:05 PM
Foxy
Status: offline
Hey Peter. Probably it just needs the driver installed. Do you hear any other sounds from the computer at all? Or is it always silent, like when you play games and stuff too?
Anyway, this should be the driver for your soundcard, try installing it and see what happens. http://www.driverskit.com/freedownload/Sound_Card/Realtek/ALC880_ALC260_ALC861_HD_R1_09/15315.html
If you normally get sound from other applications then there should be NO NEED to install the driver above. The problem is something else in that case. Let me know.
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to Xtfreak)
       Post #: 2
RE: HP Pavilion a21n Sound Card? - 12/20/2007 4:33:13 PM
Xtfreak
Status: offline
There is no sound at all, I wanted to play some music and it said " sound card driver not installed or you dont have one" so do I just need to install the driver?
thanks
(in reply to Foxy)
       Post #: 3
RE: HP Pavilion a21n Sound Card? - 12/20/2007 4:36:37 PM
Xtfreak
Status: offline
Ugh I got another problem it says I dont have a video driver?
       Post #: 4
RE: HP Pavilion a21n Sound Card? - 12/20/2007 4:55:14 PM
AutoXMan
Status: offline
quote:
ORIGINAL: Xtfreak
Re install your video card driver.
V-tec rep
       Post #: 5
RE: HP Pavilion a21n Sound Card? - 12/20/2007 6:07:37 PM
Foxy
Status: offline
Have you just reinstalled Windows by any chance? Something must have happened to have all this happen at once...
Here's what I think you should do. Save everything you want/need onto a large flash drive or separate hard disk, then run the full recovery program which will have come with the computer. It should be a CD which says recovery disk, or reinstallation disk. Normally what this disk will do is restore your PC with it's preloaded version of windows, with all the necessary drivers installed. No doubt it will need heavy updating afterwards, but at least you won't have to search for drivers. If you can't find or have lost this recovery disk, there are a number of utilities you could try which are on the support site from HP. Here is the support page for your system (I'm guessing it's actually a Pavilion a1221n, the full part number, it will be on a sticker somewhere on the outside of the box itself)... http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1148037&lang=en , it has all the drivers you may need except sound for some reason.
I'd suggest (if you can't find the recovery disk), that you try the HP Software Update Utility first (at the bottom of that page I linked above)... Back up everything you don't want to potentially lose, right now, to save a disaster happening if anything goes wrong. Bear in mind if you do run the recovery disk, it will be clean, like it came from the factory, you'll have to reinstall EVERYTHING.
(in reply to AutoXMan)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
