KRO
IL, USA Status: offline
quote:
Im thinking of getting the Trinity Now, just saw the release of the Losi Speed-T, have some questions: 1. Will the current setup of the Trinity work with NIMH batteries as well? I saw a post in here about the low voltage esc, so presumably yes? 2. With the included LIPO pack, what is the typical run time? One use said 20 min and the other 9. 3. Would you say this goes as fast as a Revo? Most people agree at about 40mph. 4. How stable is the car at high speeds, does it flip? If there is no control, I would wait for upgrades. 5. Are dean plugs to tamiya converters available (assuming I buy another LIPO that has a Deans Plug)? I understand the battery pack for charging takes Deans plugs but for the use in the vehicle tamiya. 6. Any thoughts on the Trinity NOW vs the new Losi Speed-T? Ok , here goes ........ 1. I would bet that with NiMh batteries it would cog pretty badly , they just dont have the punch that a LiPo does . The NOW comes with a Mamba 25 ESC which is pretty much the standard for mini brushless ESC's 2. I have gotten well into 20 minute runtimes , if you tone down the ESC it will run longer . 3. In a drag race I bet it would beat a REVO 3.3 till about 50-70 feet till that 3.3 gets going . 40 mph is very belivable with this car . I am going to clock mine when it gets a little warmer . 4. This car is VERY stable at high speeds ! steering is nice and tight and it holds a straight line at top speed . 5. Sure there are adapter plugs for Tamiya to Deans , but the Tamiya connectors suck sooo bad its just better to convert to the Deans Ultra plugs IMO . The battery does NOT use the Tamiya plug to charge with it uses a balancing charge lead that is a little white plug with 4 pin holes in it . 6. The NOW and the Speed T are 2 TOTALLY different animals , ones a 1/16 4WD truggy and the other is a 1/10 2WD stadium truck ......... I would think the NOW is gonna be better off road , I have a JATO 3.3 and its a real handful to keep under control . I'd imagine the Speed T would be the same way , too much power and not enough grip . The Speed T is also gonna need some expensive batteries to get to those high speeds also . Hope this helps you out .... K
_____________________________
RC18 MT , MGT 4.6SE , REVO , Trinity NOW , JATO 3.3 , LST2 , Mini T , Micro T , MLST2 , E-REVO
