KRO
IL, USA Status: offline
I got my Mini Inferno ST CVD's and I was able to install the rear alloy arms , I did have to file about .5 mm from the inside of the a arms becasue the Trinity bearing carriers are a little wide for the Mini Inferno ST arms . But they went right on after that with no problems and the suspension works the same as before ! I have another set of MIP CVD's coming and the Mini Inferno ST front upper arms , I may have to file some from the front lower arms but I am not sure yet . You also need the Mini Inferno ST turnbuckle set . Its really nice , the Mini Inferno ST arms make the car about 1/2 - 3/4 of an inch wider and I didnt loose any ride height either . I am betting that if you used all of the Kyosho Mini Inferno ST suspension parts (a arms , upper front arms , turnbuckles and steeering links) and CVD's they would bolt right up . I will probably buy a set of the KMI ST plastic ones in case the alloy doesnt hold up . I dont have a camera cause I loned it too my son and he hasent returned it yet .
< Message edited by KRO -- 3/18/2008 5:43:42 AM >
_____________________________
RC18 MT , MGT 4.6SE , REVO , Trinity NOW , JATO 3.3 , LST2 , Mini T , Micro T , MLST2 , E-REVO
