ncalenda
Joined: 3/21/2007 From: Seaside, CA, USA Status: offline
We built an outside track and when we run the NOW trucks the steering will get messed up. We find that it won't turn to the right, we pick up the truck, and visually it looks good. I also noticed that when you straighten it that will go off as well. I'm using a 2.4Ghz radio which I use on other trucks, so it is not that. Do you think it is the servo or the hardware? It is a pain, we can't be adjusting it before, during and after a race. More info, I notice the plastic servo arm will bend, so I was thinking of getting an aluminum arm. I also think that the servo is not going back to dead center when the radio is set to center. When I use it, let's say I set the center, the truck goes straight. Even in the house on carpet, and doing laps around the living room, the center will be off after a few laps. So, I adjust it on the radio and then run it again, same thing over and over. There has to be a way to get this to work better, so I was thinking a new aluminum servo arm and a new digital servo. I have no idea what servo is best for a 1/16th truck, any ideas?
