Johnnysplits
NY, USA Status: offline
Hey german27, I have the car. So far, I think its a good car BUT you have to get good tires for it like Allan said. Ive cut the shock springs down, changed the shock oil, lowered the ride height, packed heavy grease into the diff as to lock up the gears somewhat and all my car does is spin the tires like its on ice. My last hope is getting a set of the softest grp tires and see what happens. The only major thing that I suggest you change immediately is the Tx and Rx. No problems with the stock servos so far, but the stock radio equipment sucks big time!! As far as changing the engine for something bigger....see how fast you can get it first. If you need more speed, swap out the stock engine for full mod zenoah.
