Carden 260 40% Set-up Questions
Tower Hobbies
Logged in as Guest
  Printable Version
Dave Patrick Models Extra 330L - RTF
Seller:  cdp2buck
Details:   $845.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> Carden 260 40% Set-up Questions
Page: [1]
Login
Carden 260 40% Set-up Questions - 12/21/2007 1:57:03 PM
Mark786
Status: offline
I am finishing up my first Carden 260 40% build and have a couple of set-up questions for those of you that have done it before.
1. Choke set-up Do you just drop a 4-40 rod down through a grommet on the cowl?
2. Where are you running the gas vent tube?
3. This is also my first three blade prop. Do you set the blade position to be straight up on compression. Another words 12-4-8 or 2-6-10.
That's it for now. Pictures would be great.
Oh and has anyone put air in a Kavan 5" tire before?
Mark
       Post #: 1
RE: Carden 260 40% Set-up Questions - 12/21/2007 2:24:53 PM
exeter_acres
Status: offline
answered at the "other" site
_____________________________
I would like to earn your vote for IMAC Southeast Regional Director
(in reply to Mark786)
       Post #: 2
RE: Carden 260 40% Set-up Questions - 12/22/2007 3:26:20 AM
capflyr
Status: offline
(in reply to exeter_acres)
       Post #: 3
RE: Carden 260 40% Set-up Questions - 12/22/2007 5:45:03 AM
krayzc-RCU
Status: offline
yes or use a servo operated choke
out the bottom of the cowl or down the firewall
2-6-10
smooth as silk!
(in reply to capflyr)
       Post #: 4
RE: Carden 260 40% Set-up Questions - 12/26/2007 8:25:50 PM
Mark786
Status: offline
Thanks all,
I maidened the plane this Christmas weekend and had a very good first flight.
I ran the three blade prop 2-6-10 as most recommended and that worked well.
Ran a 4-40 rod down through the cowl with a grommet. Since the arm is straight up when open I drilled my first hole too far back and it kinda jambed when closing the choke.
I drilled another hole further forward and that worked much better.
I ran the vent tube down through the motor box and beside the canisters. I didn't think the cans got hot enough to melt the Tygon tubing so I didn't do anything to protect the tube.
When refueling after the second flight the fuel spit back at me, meaning a pressurized tank. I had let the tubing touch the can and it melted shut.
I have since added a clamp to get it away from the can.
Thanks for the advice but seems I aways learn the hard way.
Mark
(in reply to krayzc-RCU)
       Post #: 5
RE: Carden 260 40% Set-up Questions - 12/27/2007 11:50:50 AM
krayzc-RCU
Status: offline
man that is great!
smooth as silk!
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
