when is a regulator needed
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> when is a regulator needed
Page: [1]
Login
when is a regulator needed - 12/22/2007 8:27:03 PM
incarus
Status: offline
I am building a extra 300 with a 12 cell A123 pack with a CC hv110 esc. I will be using 5 servos(not digital) I will probably make a reciver pack out of some A123 cells..
I have heard some mention of requlators. what is this and when do you need this regulator.
how many cells do I need for the reciver pack if I use A123 cells
thanks
       Post #: 1
RE: when is a regulator needed - 12/22/2007 11:56:12 PM
everydayflyer
Status: offline
Two (2).
quote:
I have heard some mention of requlators. what is this and regulator.
Voltage regulators of which there are two kinds. Linear and switching. Used most often to provide either 5 or 6 volts to the receiver / servos from a higher voltage battery such as a 3S LiPoly.
When you are so good that you can tell the servos are slowing down alittle because the receiver pack has lost a little voltage or when you want to impress your flyning friends because you have more gadgets that they do..
http://www.rcuniverse.com/forum/m_6261387/tm.htm#
http://www.dimensionengineering.com/switchingregulators.htm
Charles
< Message edited by everydayflyer -- 12/23/2007 12:16:05 AM >
(in reply to incarus)
       Post #: 2
RE: when is a regulator needed - 12/23/2007 1:26:07 AM
incarus
Status: offline
thanks...so I quess I will not bother with the regulator. I dont need more stuff to complicate matters
Ill power my shp with a 12s A1123 pack and the reciever with a 2s A123 or the A123 1100mAh
(in reply to everydayflyer)
       Post #: 3
RE: when is a regulator needed - 12/24/2007 12:18:44 AM
cyclops2
Status: offline
INCARUS.
Keep it simple.
If you are a unlucky person, there is NO GADGET that will save you.
Battery, motor, ESC, rec., servos-nondigital. That is all you need to fly any size plane.
Do not try to be super perfect. The GADGETS fail as often as other parts......
Relax!!!!!!!!!!!
Rich
       Post #: 4
RE: when is a regulator needed - 12/24/2007 3:58:34 PM
dick Hanson
Status: offline
Each additional part is an additional failure point
having looked at all the power expanding devices for sale -and the inclusive regs and balancers (what the fuc- are those good for ) It looks to me like most of the products were designed to enable use of those low output LiIon cells which were/are accidents waiting to happen.
A cell which is subject to failure from overload - overcharge - over discharge undercharge -you name it.
I never could understand that game----
The LiPos some guys strap in now -into high vibe enviroment -really surprises me - these suffer from much of the same technology attributes - but they do allow heavy discharge - for a time-----till the delicate assembly setups turn to crap-- My last go around with these was a dis assembly of a large pack -to make smaller packs - tho I had ZERO contacts or shorts - two cells were zip- I threw the mess away - the final straw-
Having subjected my 2300and 1100 ma packs to cruel and unusual use - -but no sledge hammer stuff-
I really think they are NOT simply an alternate method -but - a far better method.
The NiMh technology of the present is now very good -but do a cell count - 5 Nimh cells to do what two A123 will do?
let me think about that one --
< Message edited by dick Hanson -- 12/24/2007 4:04:06 PM >
_____________________________
I am watching you ----
Libby
(in reply to cyclops2)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.471RCU1
