which side has more amps
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> which side has more amps
Page: [1]
Login
which side has more amps - 12/23/2007 4:11:26 AM
incarus
Status: offline
are there more amps going through the connector between motor/esc or the connector between esc/battery. or are they the same
high amp connectors are expensive so if I can put high amp connector at one point rather than points that dont need such connectors would save some money
I could possibly expect about 85 amp possible(what motor is capable of) I was planning on puting 6mm bullets between motor/esc( the wire one the cc110HV used 10 guage wire) these get pretty expensive. I was told my Castle that I could use deans ultra connectors between bat/esc. these are more affordable.
I know that other connectors are availabe with high amp applications(power poles) but these are also expensive
I would rather not use bullets at the battery/esc in fear of accidently shorting them out due to exposed ends although I could take extra precautions to prevent cross connecting/shorting
im told deans are good up to 60 amps which leads me to the above question . i will be using 12s A123s
< Message edited by incarus -- 12/23/2007 4:21:58 AM >
       Post #: 1
RE: which side has more amps - 12/24/2007 12:11:15 AM
cyclops2
Status: offline
At 85 amps & way more in a unusual load condition, I would be using a small set of Sermos type connectors. They have very conservative ratings & are VERY safe from melting and shorting to anything. Good cheap versions are available MCMASTERS.
At 85 amp power ranges, connectors are pennies compared to the total cost........Go for it.
(in reply to incarus)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
