RE: Spark F3A, from Krill Models - SPAIN TEAM
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Spark F3A, from Krill Models - SPAIN TEAM
Page: <<   < prev  1 [2]
Login
RE: Spark F3A, from Krill Models - SPAIN TEAM - 4/1/2008 4:29:00 AM
elan120
Status: offline
Andre,
Thank you for the contact information. Is the stab and canopy attachment method the same as CARF Integral? Everything else looks to be straight forward.
Looking forward to your flight report.
Thannk you,
Kevin
quote:
ORIGINAL: Dre
I have a Spark that is close to being ready to fly. Construction/effort is similar to the C-ARF Integral. Details about the Spark can be found at www.krill-model.com.
The U.S. distributor is as follows:
Phone: 603 781 8352
Fax: 603 629 9766
Email: pbarnnett@skylineaviationonline.com
Address:
Sky Line Aviation L.L.C.
P.O. BOX 5559
Manchester, NH 03108
Andre Bouchard
(in reply to Dre)
       Post #: 26
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/2/2008 9:22:44 PM
awat65
Status: offline
What is the C.G for the Spark?.
(in reply to Patterndude1)
       Post #: 27
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/19/2008 10:23:47 PM
Dre
Status: offline
Here is some information my Krill Model Spark:
The as-received weights were:
Fuse+canopy=918 gr.
L. Wing=393 gr.
R. Wing=382 gr.
L. Stab=109 gr.
R. Stab=111 gr.
Rudder=86 gr.
Wing Tube=62 gr.
Stab Tube=14 gr.
LG=125 gr.
Wheel Pants=40 gr.
The finished weight is 4767 gr. with the following equipment:
Hacker C-50 13XL Comp+Comp 90 ESC
FlightPower 5350 F3A 10S
APC 20.5x14
Futaba 3xBLS451 (Ailerons and Rudder)
Futaba 2x9650 (Elevators)
Futaba 5014Rx
Futaba choke on ESC
Jaccio Voltage Regulator
Some notes: ESC was mounted where it is and an air scoop was added to increase cooling—we fly in 90+F most of the summer in south Texas. The batteries need to be well forward if the servos are mounted in the stab due to the long tail moment/short nose moment (see pictures).
Set-up is per plans (all incidences at zero and CG at 30mm from center of wing tube).
Flights to date indicate the following:
Despite the counter-intuitive (to me) all zero set-up, the vertical lines and knife-edge trim are very good.
There is no pitch or roll couple with rudder on knife-edge or flat and level with this set-up. You can make perfectly flat rudder turns with no inputs.
Given the fuselage side-area, the side force/fuse lift is very powerful. However, yaw control is not overly sensitive.
The snaps are effortless thanks to the saw-toothed wing leading edge and high wing taper.
Stability in the wind seems quite good.
Overall, I am very pleased with the design/quality of the Spark.
Regards,
Andre Bouchard
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dre -- 5/28/2008 2:57:42 AM >
(in reply to awat65)
       Post #: 28
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/23/2008 6:08:56 AM
kjpsen
Status: offline
Here is a picture of some SPARK's flying in Denmark, the one in GM-scheme equipped with Dualsky 6360 motor. The 2 in AZ-scheme flying with AXI5330, all off them using Hitec servoes, and flying weight approx 4700 gr.
Great flying models.
Click for fullsize
(in reply to Dre)
       Post #: 29
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/23/2008 9:33:44 PM
lyka
Status: offline
COngratulations !!!!!!...
If do you want say me, about motor Dualsky..... if is OK ?????....
We have in our two Spark , Hacker motor.....I am thinking to the future in Dualsky´s motor....
Thank you.
Andres Girabel
SPAIN.
Click for fullsize
Click for fullsize
(in reply to kjpsen)
       Post #: 30
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/24/2008 9:51:29 PM
ColinW
Status: offline
Hi,
I'm hoping to put a Plettenberg in my Spark - does anyone have a good outline of the former that I will need to fit in the nose? Also what material do you recommend for this former? I am planning a carbon/ply/carbon sandwich.
Colin
(in reply to lyka)
       Post #: 31
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/25/2008 8:36:44 PM
kjpsen
Status: offline
Hi
The Dualsky are doing the job very well, lots of power, i'm really impressed of this motor. Running quit and "smooth", and at an very affordable price, but ......... so far i just have about 30 flights on it. So how long it will hold on i cant tell you yet.
Oh.... and just another photo from yesterday ' '' ',''))
Click for fullsize
(in reply to ColinW)
       Post #: 32
RE: Spark F3A, from Krill Models - SPAIN TEAM - 5/25/2008 9:06:07 PM
lyka
Status: offline
Jeg vil overveje din mening
mange tak.
du vil nyde dette store fly.
vi er meget glade
I shall consider your opinion
thank you very much.
you will enjoy this large aircraft.
we are very happy
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 33
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
