RE: Spark F3A, from Krill Models - SPAIN TEAM    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> RE: Spark F3A, from Krill Models - SPAIN TEAM
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Spark F3A, from Krill Models - SPAIN TEAM - 6/28/2009 3:10 AM
lyka
Score: 100
Last Login: 1/30/2012
Status: offline
Today, maiden flight....all perfect !!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
BLOG:
http://jonathangirabel.blogspot.com/
Hide Signatures
(in reply to AAbdu)
       Post #: 101
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/1/2009 7:43 PM
joenella
Score: 100
Last Login: 1/14/2013
Status: offline
quote:
ORIGINAL: lyka
Congrats's!!!
That is one good lucking plane!
I will pick up my no. 3 SPARK in 2 weeks
By the way, I have noticed that my motor can be a bit hot after landing and no airflow to cool it down, so I have bought the following http://elektronik-lavpris.dk/product_info.php?products_id=104986 solder plug on and now I'm able to cool mu mototr when landed, it uses 3S and take 100 mAh.
Joen
Hide Signatures
(in reply to lyka)
       Post #: 102
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/1/2009 11:50 PM
lyka
Score: 100
Status: offline
Thanks Joe....
The fan is good idea...and very effective !!!!...
best regards
BLOG:
Hide Signatures
(in reply to joenella)
       Post #: 103
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/2/2009 8:29 PM
joenella
Score: 100
Status: offline
Just a small notice about my cooling fan.
Today was the first day I used it, normally I have to wait about 60-70 min to cool down the motor(hot temperatures outside) but with the fan I only needed 17-20 min to get it cooled down so on a normal day I will get around 4 flights, today I managed to get 6 flights.
So boys start your cooling fan and enjoy more flying
Hide Signatures
(in reply to lyka)
       Post #: 104
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/2/2009 10:33 PM
flyboy91
Score: 105
Last Login: 6/19/2013
Status: offline
That is great news.
What motor are you running in your Spark, forgive me if I didn't see that before and what temperature is your motor coming down from a flight at?
Andrew
Hide Signatures
       Post #: 105
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/2/2009 10:41 PM
joenella
Score: 100
Status: offline
quote:
ORIGINAL: flyboy91
That is great news.
Andrew
I'm using MEGA ACn F3A and it it is fairly hot around 70-75 degree C, manufacturer says it is no problem and it seems to be ok. Running a Mejzlik 22x12WE prop.
At the moment we are facing high 20 temps nearly 30 in the shadow, in the sun more like 40-45 degree. You must expect something similar in Portugal during WC
Joen
Hide Signatures
(in reply to flyboy91)
       Post #: 106
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 4:26 PM
flyboy91
Score: 105
Status: offline
quote:
ORIGINAL: joenella
Joen
During my practice my motor is coming down about 60C or 140F. Usually with in 10-20 minutes I'm ready to fly again with the motor down to 110 degrees.
Andrew
Hide Signatures
       Post #: 107
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 7:13 PM
tommy s
Score: 101
Last Login: 6/18/2013
Status: offline
I found a use for my old glow starter battery !! I use it to power a 12 volt computer box fan
that I purchased from Radio Shack to cool down my Hacker outrunner after a flight. Temp
goes from very hot to the touch to cool in about 10-15 minutes. Battery charge lasts for a few
weeks.
tommy s
Hide Signatures
       Post #: 108
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 9:26 PM
flyboy91
Score: 105
Status: offline
Do you just put the fan in the front intake and let it go by the motor and out the fuse? Just wondering. This seems like it may be good information to have if people are having problems with there motors running hot.
Andrew
Hide Signatures
(in reply to tommy s)
       Post #: 109
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 9:59 PM
can773
Score: 105
Status: offline
Computer fans work great, I dont use them to cool motors but I hook two of them up to the 12V supply on the charger to force cool batteries down so I can recharge sooner. Makes it possible to keep flying with only two packs and two chargers.
Andrew, you manage to get JAS out of bed yet
Chad Northeast
Hide Signatures
       Post #: 110
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 10:03 PM
joenella
Score: 100
Status: offline
quote:
ORIGINAL: flyboy91
Andrew
No problem I like it simpel.
Click for fullsize
Hide Signatures
       Post #: 111
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/3/2009 11:07 PM
flyboy91
Score: 105
Status: offline
Chad,
Jason just made it in to Dtw. He isn't feeling so hot. When I leave work we will head out to the flying field.
Andrew
Hide Signatures
       Post #: 112
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/4/2009 9:43 AM
f3a05
Score: 100
Status: offline
We’ve had relatively high ambient temps here recently(30degrees C).
I don’t have an accurate measure available, but my Plettenberg motor was landing too hot to touch, and taking 30 minutes to cool sufficiently for me to feel happy about flying again.
This “spinner with the nose cut off”,with a skeleton aluminium back plate, allows me to have just a ten minute interval between flights.
[URL=http://img33.imageshack.us/i/img0245g.jpg/] [/URL]
Crude, but effective, apparently.
Hide Signatures
       Post #: 113
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/4/2009 5:32 PM
tommy s
Score: 101
Status: offline
joenella,
That is exactly how I do it also.
I use the 12 volt power supply if electricity is available and the 12 volt
battery at fields with no power available.
tommy s
Hide Signatures
       Post #: 114
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/4/2009 6:12 PM
can773
Score: 105
Status: offline
f3a05
Anything above 60C is basically too hot to touch, and at 30+C it would be normal to be above that, so checking by feel is not a very good way to determine temperature. In all my time I have never felt the need to allow a motor to cool off before the next flight. Simply, the hottest point your motor will get is shortly after landing, the moment you takeoff for another flight it will cool off from that point and begin operating at normal temps. As long as your motor is not exceeding about 80C after landing measured on the outside can, then you are OK.
I have many times flown back to back in temperatures at 35C+ while at the US Nats in Indiana, where it is very hot and humid without problems.
quote:
ORIGINAL: f3a05
Chad Northeast
Hide Signatures
(in reply to f3a05)
       Post #: 115
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/4/2009 6:44 PM
1bwana1
Score: 100
Last Login: 8/16/2012
Status: offline
Yesterday I helped a friend maiden his new Spark. Plane flew great from the first flight, and just got better as he dialed in the CG, and rates. The Spark is a great snapping plane for sure. We are planning to fly some more this morning. The selfish bugger didn't offer me a flight, and I didn't ask, maybe today....
Hide Signatures
(in reply to can773)
       Post #: 116
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/4/2009 7:56 PM
f3a05
Score: 100
Status: offline
Thanks for that, Chad-it will be nice to be able to put the better-looking spinner back on!
So-if I can find/borrow a thermal probe thingy,if I remove the bottom chin cowl asap after landing, then take a reading off the can surface-as long as it's less than 80 degC everything should be OK?
Thanks again!
Hide Signatures
(in reply to 1bwana1)
       Post #: 117
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/5/2009 2:50 AM
lyka
Score: 100
Status: offline
Forward flights Spark Dynamic, in sequence video...
There are a little difference with old Spark, but great difference on the air !!!!.
Final weight with LIPO 4350 mAh , 4,550 grs (4,55 Kgs) !!!!!!....
greetings.
BLOG:
Hide Signatures
(in reply to f3a05)
       Post #: 118
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/5/2009 8:21 AM
joenella
Score: 100
Status: offline
Great video!!
Yes there is a little difference in the look of the 2009 version SPARk compared to the "old" versions, but in the air there is big difference, new one is just very very "crisp" and clean.
Hide Signatures
(in reply to lyka)
       Post #: 119
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/5/2009 9:38 AM
1bwana1
Score: 100
Status: offline
Bisides the paint schemes, what did the change on the 2009 version?
Hide Signatures
       Post #: 120
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/5/2009 9:59 AM
joenella
Score: 100
Status: offline
quote:
ORIGINAL: 1bwana1
Rudder have new shape is without balance tap and more dihetral on the wings. Beside this is I think there has been a slight change in weight distribution back to front.
Joen
< Message edited by joenella -- 7/5/2009 10:14 AM >
Hide Signatures
       Post #: 121
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/5/2009 10:42 AM
sd_raptor
Score: 100
Last Login: 4/18/2010
Status: offline
I maidened my 2009 Spark yesterday. I set the CG a bit forward for the first flight. No aileron trim needed. One click of rudder. A couple clicks of up elevator as expected with the forward CG. Two more flights to adjust CG to put it just behind trailing edge of wing tube. With 15% aileron differential, downline rolls are perfectly axial. Following 1bwana1's advice, I backed off on rudder and aileron rates. On the next flight snaps were incredibly crisp - stopping immediately when controls went to centers. I was doing all this in a 15mph (23 kph) wind that was at 45 degrees to the runway - the Spark needed almost no rudder to stay on a nice line parallel to the runway - it weathervanes almost perfectly.
Landing was quite different in the cross wind compared to my 25% ExtremeFlight Yak and 35% Comp-Arf Extra: instead of needing to add rudder to rotate the nose into the crosswind, I needed just a touch of opposite rudder to hold the centerline down the runway.
There is very slight coupling to the gear when applying rudder - easily dialed out with a rudder to elevator mix.
Landing is very easy since the plane shows no tendancy to tip stall at low speed.
Power is Neu 1515/3D with 6.7:1 heavy duty gearbox, CC HV-85 ESC, Mejzlik 20x12E prop. More than enough power for great uplines. Also very efficient: My last 8 minute flight used only 2650 mA-Hr from the packs.
With two 5350 5S Flightpower F3A batteries, the all up weight is just slightly over 5kg. I can easily reduce weight by cutting the flight pack batt from 2S-1300 to 2S-850, by reducing main batts to 4300mA-Hr, or by swapping out the 1515/3D for a Neu F3A-1 Motor or by replacing the 8oz P42 gearbox with the 2.3oz P32 gearbox.
Amazing plane that looks marvelous on the runway or in the air and flies with no effort at all.
Hide Signatures
       Post #: 122
RE: Spark F3A, from Krill Models - SPAIN TEAM - 7/7/2009 6:04 PM
flyboy91
Score: 105
Status: offline
Congrats on the flights. I now have both Sparks in my scheme flying very well.
Andrew
Click for fullsize
< Message edited by flyboy91 -- 7/7/2009 7:50 PM >
Hide Signatures
(in reply to sd_raptor)
       Post #: 123
RE: Spark F3A, from Krill Models - SPAIN TEAM - 8/17/2009 7:15 PM
sleeping
Score: 100
Last Login: 5/11/2011
Status: offline
This is only one of two in Australia.
But after the World's with Andrew at the sticks, I think that's going to change very quickly.
- James
Click for fullsize
Hide Signatures
       Post #: 124
RE: Spark F3A, from Krill Models - SPAIN TEAM - 9/11/2009 11:08 PM
Neil Collins
Score: 105
Status: offline
Hi Andrew
Congrats on your 11th placing in the worlds, I think it is an awesome achievment. It must be difficult chosing the top ten when everyone flies so well.
My Spark is going very well over 400 flights so far and the airframe is holding up very well. I am in love with your scheme as well as the black and yellow flame.
Is your scheme a custom one or is it offered by krill?
Cheers Neil
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
