Need a little guidance
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Need a little guidance
Page: [1]
Login
Need a little guidance - 12/24/2007 5:06:55 AM
amdhotprocessor
Status: offline
Ok, thinkin about trying some tuned pipes and already have a few designs and sizes thought thru and ready to go, BUT, instead of metal I want to use carbon fiber weave. So, I need to know, Since i want to make some carbon landing gear too, can the mat that i use be the same weve size(hopefully very small) and i will not be vacume bagging or anything, I just want to hand lay up.
What the plan is, Is I want to build a 1 piece tuned pipe and experiment with different shapes and sizes, so i need to know if i could use fiberglass or carbon fiber? what resins? I know that some sport bikes have real carbon fiber mufflers and my car I put a greddy carbon can muffler.
I would like to use the finest mat I can but I dont know how they rate the sizes and stuff. All the help availible is greatly appriciated. Mb
_____________________________
fly it like its free..heheheh
       Post #: 1
RE: Need a little guidance - 12/26/2007 3:26:08 AM
amdhotprocessor
Status: offline
any idea of what resins to use for high temp?
(in reply to amdhotprocessor)
       Post #: 2
RE: Need a little guidance - 12/26/2007 3:58:30 AM
Bad_Daddy
Status: offline
As long as you're running nitro, good epoxies will work, because the exhaust temps from nitro are lower than from gasoline engines, and will not cause the polymer chains in the epoxy to dis-bond. A car's muffler is far enough away from the engine that it does not see the full temp of the exhaust, like the header pipes do.
There are high temperature resin systems available for pre-preg carbon, but those require autoclave pressures and temperatures to cure, plus a vacuum bag for material consolidation.
Just remember, if it was easy, everyone would be a TopGun pilot.
bad0daddy
       Post #: 3
RE: Need a little guidance - 12/26/2007 1:38:09 PM
amdhotprocessor
Status: offline
Ok, thanks. Now is it okay to use fiberglass for this typr of app. I would rather practice with fiberglass and then remake it in CF when Im happy with it
(in reply to Bad_Daddy)
       Post #: 4
RE: Need a little guidance - 12/26/2007 2:05:21 PM
Ed Smith
Status: offline
Go here.
In the past I have purchsed high temperature epoxy resins from them that did not require any specialised equipment for curing. It was for tuned pipe use.
www.acp-composites.com or www.acpsales.com
Ed S
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
