Glasssing / Which is Stronger?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> Glasssing / Which is Stronger?
Page: [1]
Login
Glasssing / Which is Stronger? - 12/25/2007 8:30:16 AM
rednekk58
Status: offline
Hi All,
Building a wing, bare skeleton, sheeted with 2 mm depron. will apply two layers 3/4 oz cloth. I also have 2 oz. cloth. No vacuum bagging just brush a squeege.Was wondering which would be stronger? Two layers 3 /4 or one layer 2 oz. Which would be lighter? Opinions?
Al
_____________________________
There is a fine line between insanity and genuis.
I'm almost a genuis!!!
There is a fine line between insanity and genuis. I'm almost a genuis!!! NeArLy NoRmAl Al
       Post #: 1
RE: Glasssing / Which is Stronger? - 12/25/2007 1:28:20 PM
Ed Smith
Status: offline
In both cases the two layers of 3/4 cloth will be stronger, stiffer and lighter if applied correctly. Cloth weight is stated in ounces/sq yard. The generaly accepted ratio of cloth to resin is equal weight of each. Therefore the weight saving with two layers of 3/4 cloth will be 1/2 ounce/sq. yard over the one layer of 2 ounce.
For strength lay on the first layer of 3/4 cloth. Use your favourite method of removing excess resin. before the resin has completely cured (Still kind of tacky) squeegee on the second layer with the weave at a 45deg angle to the first layer.
Ed S
(in reply to rednekk58)
       Post #: 2
RE: Glasssing / Which is Stronger? - 12/25/2007 1:46:54 PM
rednekk58
Status: offline
Thanks Ed,
This helps a lot, That's what I'll do.
Al
Merry Christmas Everyone
< Message edited by rednekk58 -- 12/25/2007 1:48:33 PM >
(in reply to Ed Smith)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.219RCU1
