rc boat fuel
Tower Hobbies
Logged in as Guest
  Printable Version
CRRC-Pro GF26I 2 stroke gas engine
Seller:  jewillis2
Details:   $199.88   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> rc boat fuel
Page: [1]
Login
rc boat fuel - 4/9/2003 12:28:23 AM
lap cat 1 racer
Status: offline
I us 65% nitro in my K&B .21 on a prather lap cat 1 is this too much nitro? also does anyone have a suggestion on which prop to use
Lap cat racer
       Post #: 1
rc boat fuel - 4/9/2003 1:45:45 AM
Turn&Burn
Status: offline
I would not run 65% in a k&B .21 Way to high for that motor....If you want some good kick I would not go any higher than 40%...On the prop a prather 215 works fine on 21 tunnels.....It did on mine........BTW are you having probs keeping a needle setting??? If that is a full blown moded motor forget what I have just said
(in reply to lap cat 1 racer)
       Post #: 2
65% nitro - 4/10/2003 12:39:31 AM
lap cat 1 racer
Status: offline
my k&b .21 is stock but is under going full race mods by rooster tailz I have heard that these engines can make up to 2.8 hp is there any truth to this? if so that lap cat 1 will FLY!!!! any body have suggestions for a prop?
lap cat 1 racer
       Post #: 3
Re: 65% nitro - 4/10/2003 8:15:33 AM
Turn&Burn
Status: offline
[QUOTE]Originally posted by lap cat 1 racer
lap cat 1 racer
[/QUOTE]
With mods, absolutely!!!!
       Post #: 4
rc boat fuel - 4/11/2003 12:04:21 AM
lap cat 1 racer
Status: offline
turn&burn i am not haveing trouble keeping a needle setting but i run mine on the verge of dying from lack of fuel it is so lean but it gives awsome speed
       Post #: 5
rc boat fuel - 4/11/2003 3:17:30 AM
Turn&Burn
Status: offline
The higher the nitro the harder it is to keep a needle setting.......I have Picco (heavily cut on) .21 and since it has been cut on and a custom machined big bore carb installed, it will not even hardly run at any throttle setting except at WOT......If you let off on it, it is still just dumping fuel in it so it just bogs down But when it cleans out you better be ready... I am running o'donnell 50 and this little mono will freekin fly....It is hard to tell but I just about bet you if you lower your nitro to 25-35 on a stock engine it will be easier to tune and run....might not run as fast, but fewer headaches...and also not risking frying you engine before you have the chance to mod it.....
< Message edited by Turn&Burn -- Apr 10 2003 10:25PM >
       Post #: 6
rc boat fuel - 4/11/2003 7:13:15 AM
lap cat 1 racer
Status: offline
I have a os .61 fx i just took the carb off and put it on my K&b .21 and i bet it picked up 5 to 10 mph any body else doing this?
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.000RCU1
