soloboss
IN, USA Status: offline
Hey Max, You've earned your place here on this thread. I wouldn't worry a lot about getting tossed. And when you reach the point where you are the PRO, then you become the teacher and you still have a place here. Seems you are stuck with us. You asked about my coming to terms with the CP. We're buddies, but the current state of the economy has my job tanked. Prudence would have me leave the big bird on the shelf. My feelings for the CP are that its really excellent. Maybe a metal head would improve response but the Belt uses metal balls for all of the link connections. It's tight I noticed that some of the metal upgrades still use plastic links in the critical locations to protect the expensive metal bits. Since I fly upright that's OK. Others would want a full metal head. Anyhow, The sound of the blades as they rip the air and the control of the tail is something you have to experience to appreciate. CP's are great - when the flier is ready. I'm in no particular hurry to get proficient at CP, so I'm just enjoying the ride as I work through the mods. But I did mess with the Falcon a bit. And I shot some video of it working in the garage. The hover is very stable with the blades tight but I'm running them really loose at the moment. I haven't quite figured out how to get a really good blade balance, or maybe my shaft is tweaked. Anyhow, something is outa whack. So I loosened the blades and they cone a bit due to the loose screws. After the video is done uploading I'll tear into the Falcon and get it all true again. Man the video on Vimeo uploads slowly. I have a 250mb file going up at 45kb/s. Another hour and 22 minutes and it'll be done. I need to post much smaller video. Next time. The video is supposed to be far better and we'll see if it's worth the slower upload. Anyhow, for those following this, this is what you're watching. Falcon 40 with Slo Max motor, Xtreme 8° woodies, 900 mah 20c LiPO, Blade CP tail motor, Super Skids. Flight weight is 343 grams. I'll edit this with the location of the video when it's up. Or go to vimeo.com and use the tags Falcon 40 and Soloboss. Another hour and 22 minutes and it'll be up unless my DSL hook decouples. Soloboss
_____________________________
Soloboss If everyone''s thinking alike, then somebody isn''t thinking . . . G. Patton
