RMG2
OR, USA Status: offline
quote:
ORIGINAL: xyster101 I am a teacher, Wood Shop at the high school level with all my fingers still! Crashing is part of the fun. Some of you guys are very particular about your birds and take a great deal of time setting them up and getting them to fly perfect. That is great and I am sure you have a wonderful flying bird. Me, well I don't mind a crash here and there. It hurts the wallet some, but it is a chance to sit in my office, put on some old streaming netflix shows and go to town! I live for the crash! I am good at coming towards myself nose in and then banking away. I was actually practicing doing circles bank. It is like a figure 8, which is easy now, but just keep the bottom of the 8. It is hard for some reason. the heli tends to loose altitude as it funnels down and I think it might have rolled over to an inverted position, well anyway, nose first into the dirt. Some how the blades did not break! Give me 2 hours, some tape, and we will be good to go! It might pull to the left or twitch some, but it is like driving an old car, has personality! Bones, the B400 is a great heli for the money. It comes with the TX, battery, charger everything you need in one box. You will eventually upgrade the gears as they strip easily on a crash. But you are not supposed to crash. I have Hitec65's with metal gears and they hold up to crashes, now my linkage bars bend instead. I am happy with the performance, customer service and avalibility at my LHS of parts on this bird. I would buy it again. The Trex is nicer, I have flown one, but at almost a few hundred more, not worth it for what I do. Wood Shop..., I guessed you were the Home Economics Teacher, you know, sewing and such Wait a minute..., I was dating the Home Economics teacher the year after I graduated from High School and she was a "hottie", unlike you Maxine Guess she thought it was okay since I was no longer in school! Okay, I'm not going there Max, Knowing you like I think I do now, if I had seen your crash I would have ribbed-ya mercilessly buddy, and expect the same from you in return To bad about the battery though Do you guys fly 315MM blades on those 400's, or what length? I'm waiting for an 11T pinion to arrive before I can fly the MT with the Turnigy motor Headspeed with the 13T exceeds the capacity of my blades and running the throttle curve so low (to keep the headspeed down) is causing my ESC to get way to hot In fact, my 45AMP ESC might not cut-it with this motor, will know when I get the RPM up and the head speed down??? Will have to put more flights on the FP the next couple days.
