gene465
FL, USA Status: offline
quote:
ORIGINAL: memphissound can anone give me some ideas on setting for the blade 400 for a beginner i started flying with a cx2 about a year ago and this thing is just wild compaird to it so if anyone has somthing im getting really sick of fighting it please dont say buy a tret 450 cannt afford it right now Memphissound, The Single Rotor helos are a completely different animal than the little CX2 which is very stable and tame helicopter. Most of us on this thread started with the CX2 and have since moved up like you have. I now have 3 Trex 450s but am using the same radio as the B400 and the best advice I can give you is to make sure your helo is set up properly mechanically, ie swashplate level, pitch should be at 0 Degrees at mid stick in Idle up(ensure you have two wires disconnected on your motor before checking! ) etc. Going into the programing on your radio set your starting pitch to 40-45 degrees this will limit your - Pitch, set your dual rates on your cyclic to about 60-65% with about +25 Expo this will limit servo throw and make it less sensitive to inputs, making sure your CG is correct try hovering with your dual rates on. Make sure your Gyro is properly holding the tail and adjust as necessary. Feel free to bounce any questions off the collective here we were all in your shoes starting out. The Blade 400 is a fine helo to learn on so no one is going to tell you to just get a Trex! They are both similiar Helocopters and they all fly the same. Brand is just a matter of personal preference and affordability. Welcome to the thread! Gene
_____________________________
T-Rex 450SE, 450SA, HBK2, Sea Fury 400, P-47D, Lancair ES, Ultra Mini Stick, Taylorcraft 450, HPI Savage 4.6
