omp edge ve build
Tower Hobbies
Logged in as Guest
  Printable Version
Ohio Model Products Fusion X3D - 90
Seller:  cdp2buck
Details:   $525.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> omp edge ve build
Page: [1] 2   next >   >>
Login
omp edge ve build - 12/27/2007 5:54:25 AM
dragnbye
Status: offline
well santa bought me a new plane this year. this is my first kit and so far i loven it. just as the title says it's ohio models planes 47" edge 540. i going to post some pic up later but, i have a few ??"s. i have 200 dollare for a engine and i been reading alot of poeple really like the o.s. 55 ax 2 stroke. i was looking around thogh and seen a o.s. fl 70 4 stroke with only a price diffrance of 30 dollars at that point who cares. i want to know which one will be better. i know the pro's and con of the 2v.s.4. next ? there is no wheel for the rear landing gear it just a tail slider. is it better to just put tail wheeel in or should i just stick with the wire.
i will post some pic up soon of the progress
_____________________________
buy a funtana 100, saito culb member 559
       Post #: 1
RE: omp edge ve build - 12/27/2007 9:26:59 AM
GUNS
Status: offline
Go with the 55AX. I have both engines. The 70fl will not give you the performance you want and weighs more. Get the Tower Hobbies muffler for $14.99 for the 55AX and use the other $15 for some 12.25x3.75 APC props and enjoy it. The TH muffler will give you about 300 more rpm than the stock one! The 55AX is also much better on fuel consumption and makes more power. The 70fl is good for "sport" type planes, mine is in my H9 40 size Cub on floats and works fine, but it does not have the performance for a profile. Now, on the other hand, if you get the OS 70 Surpass, it would do outstanding in the profile. Don't confuse the two OS 70's though, they are not the same at all!
Tim
(in reply to dragnbye)
       Post #: 2
RE: omp edge ve build - 12/27/2007 10:28:55 AM
wessco
Status: offline
Not mentioned, but a Webra 50 is also an excellent choice. It's a tad lighter than the 55 AX.
http://www.swanyshouse.com/engines/engines.aspx
Stick with the wire. You turn more with the rudder anyway. Also, you won't be taxiing it that much as it'll want to just leap off of the ground.
(in reply to GUNS)
       Post #: 3
RE: omp edge ve build - 12/27/2007 5:48:48 PM
RC MANIAC119
Status: offline
You won't need to buy that Tower muffler!! Just remove the baffle in the 55 muffler....it saves money, and gives you monster extra power!!
< Message edited by RC MANIAC119 -- 12/28/2007 6:18:32 PM >
RC MANIAC-PRO BRO 1900-AMA# 95841
(in reply to GUNS)
       Post #: 4
RE: omp edge ve build - 12/27/2007 6:05:56 PM
dragnbye
Status: offline
what about a pitts style muffer???. also any tips like beefing up any way?
(in reply to RC MANIAC119)
       Post #: 5
RE: omp edge ve build - 12/27/2007 6:09:36 PM
wessco
Status: offline
A pitts style muffler won't fit this application. You also won't need to beef up the plane, it's plenty strong as is.
       Post #: 6
RE: omp edge ve build - 12/28/2007 5:34:14 AM
jvino
Status: offline
I would vote for 13x4 props. Seems the 12.25x3.75 isn't quite enough prop.
(in reply to wessco)
       Post #: 7
RE: omp edge ve build - 12/28/2007 4:41:56 PM
AFSalmon
Status: offline
Congratulations Dragnbye and we are all here to help you on the build if you need it. Just ask away!
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to jvino)
       Post #: 8
RE: omp edge ve build - 12/28/2007 5:08:11 PM
150flyer
Status: offline
Here's mine with the OS .55 AX. With a 13 x 4W APC Prop, the .55 AX pulls it right out of a hover into unlimited vertical.
Click to see fullsize image.
Click for fullsize
(in reply to AFSalmon)
       Post #: 9
RE: omp edge ve build - 12/29/2007 4:29:43 AM
dragnbye
Status: offline
AFSalmon
hey i didnt get the cd with the plane is it the same is whats on your site
also i kind of rip a little hole in my plans do you have these on hand i live like 10 min away form your shop
also pic's tonight
(in reply to 150flyer)
       Post #: 10
RE: omp edge ve build - 12/29/2007 2:35:28 PM
AFSalmon
Status: offline
Yes, the manual is the same as what is on the websight. If you are 10 mins away give me a call at 320-5894 and I'll hook you up!
Hey 150flyer, nice picture! I thought it was ironic you took the picture of the Edge hovering in the Heli1 area!
       Post #: 11
RE: omp edge ve build - 12/29/2007 2:41:15 PM
dragnbye
Status: offline
ok so here are some pic i been workin on this for 2 days on and off. i have a ?? to pics show what i am trying to say. on the rear servo tray th oval pice i cant find also the 2nd pic just in front of the rear stab i am i to use balsa block there then the stab sit angist that??
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 12
RE: omp edge ve build - 12/29/2007 7:05:18 PM
Flexnbeef
Status: offline
The piece in the kit doesn't have the oval cut.
I never crash, The plane does !!
       Post #: 13
RE: omp edge ve build - 12/29/2007 8:13:16 PM
dragnbye
Status: offline
ya i just happen to have that pice on my table and said o i think this is it. as i said b4 this is my fisrt kit i think a profile was a good way to start. i will have more pic's up soon
(in reply to Flexnbeef)
       Post #: 14
RE: omp edge ve build - 12/29/2007 8:16:37 PM
