rctom
TX, USA Status: offline
quote:
ORIGINAL: Ih82crash So what is the length exactly? This post says 92 and The wild hare web site says 100". Also I was wondering about the power and balance with a DA 85. Is it designed around an 85 or does an 85 just work? I live at 5300' and density runs about 7500' in the summertime. I have a 3W 106 but I am afraid for the weight factor in this plane. I am considering either the DA 85 or 100. Doug The plane standing on its nose will just clear an 8 foot high ceiling, makingt it just under 96". The new Giles G202 was designed before the 85 came out but I had a lighter engine in mind when setting the plane up, that's why it comes out a little nose heavy with a 100cc twin. However, with the altitude and the power of the 106 I'd say that your engine is ideal. Wing area is not an issue, the wings are huge and you will have plenty of lift, I would be more concerned with power at your altitude and the 106 is the top of the heap in that group. It's always a quandary working at altitude, what's more important lower weight or more power. The perfect solution was the BME 110/115, which is really what I had in mind when I was designing the plane, but that engine's availability is suspect. I'd say use the one you have, it costs nothing. You can always change later if you're not real happy. TF
