Matthew007
NY, USA Status: offline
Ok I had a really bad cogging problem with my 5070 feigao in my m1025 with 21T pinion. I went down to 16T and left the esc on low timing, fast start, and 0% rpm, no volt cut-off. It helped a little and later found out I had the same problem snellemin had..one capacitor's insulation burned off and shorted the other cap. I took that one capacitor off and put a big blue 470uF 25V cap I had and it seems better. However, when I press full throttle the vehicle stops and it beeps like I need to zero position it again. I'm guessing i'm either too over geared (Im using HPI SS wheels with proline Dirt Works) or I need a correct capacitor setup. Chances are the remaining green capacitor is crapped too. Is radio shack a good place? and 3 330uF capacitors worked well for you snellemin? The original capacitors said 105 degrees Celcius.
