I plunged and ordered a $100 1:10 Brushless system
#202
NY
RE: I plunged and ordered a $100 1:10 Brushless system
ORIGINAL: mog ruith
so mathew is that the ezrun or xerun esc form hobbywing?
http://www.youtube.com/v/eW8VaT_PzZ8
#206
Hi,
interesting what you think about our products. If any questions, please email me at [email protected] ... we will have now a 70A system for 1:10 monsters and a 120A system for 1:8 monsters.
Have a look at this vid www.modellfun.com/monsternew.com
70A ESC and 4000KV motor at 7.4V
Best regards,
Michael
Modellfun Team
www.modellfun.com
Best regards,
Michael
Modellfun Team
www.modellfun.com
#207
TX
Michael,
I still use the old version ESC (repaired myself) in my son's rustler. It still runs, but only handles small loads(small motors). Is the 120A version rated at 120A RMS or peak like the old one?
#208
NY
ORIGINAL: skyartec hk
Hi,
Best regards,
Michael
Modellfun Team
www.modellfun.com
Hi,
Best regards,
Michael
Modellfun Team
www.modellfun.com
The 3300kv motor is really good though except it wont fit in many buggies cause of the built in heat sink in the middle and you NOOBS didnt even sand a flat part on the shaft so I had to do that myself.
#211
NY
ORIGINAL: snellemin
The motors were very good, but the ESC just cost too much for it's capabilities.
I owe everyone including you an apology for mentioning this rabid pos at all.
The hobbywing esc actually works and the esc never got really hot, the hottest it got was holding it for 4 seconds b4 I needed to move my finger, and that was at the end of a good run throttling a lot with 7 cells on very aggressive mode.
I'm going to test it tonight with a new 8-cell propel pack I soldered side by side with Gold Orion bars.
#214
Hi,
no, the new ESC is able to handle 120A continuously. Burst loads are about 3 times the nomial current. We still dont have it ready thus, will be by mid of August. I will post pictures of it. This new ESC series are pretty intelligent in comparation with the old ones.
Best regards,
Michael
Modellfun Team
www.modellfun.com
Best regards,
Michael
Modellfun Team
www.modellfun.com
#215
ORIGINAL: Matthew007
Your ESC I bought never performed well and was made for airplanes. Looking at it it was never worth even $20 worth of electronics, just unreliable badly engineered crap that didn't last even for less than 8-cell nimh. What's the point of an esc if it causes a significant voltage drop, you need to set zero throttle every time you turn on your land vehicle, it cogs, and never delivers the current needed to the motor to even get top speed. With the REAL esc I have now I can get speeds and acceleration I never thought possible.
Hi,
Best regards,
Michael
Modellfun Team
www.modellfun.com
Hi,
Best regards,
Michael
Modellfun Team
www.modellfun.com
As far as for the motor, we do now supply a 4000KV motor with, the housing is full-block milled, and it is completely sealed. Look at http://www.thiedemann-international....ner-Motor.html
Best regards,
Michael
#216
NY
Well your first esc was a fat lie so no thanks anymore.
Now for the Hobbywing 8-cell test run I managed to finally blow a tire as you can see in the pic lol. It sounded like when a car runs over a closed plastic bottle. I was getting new rims/wheels so I tried to blow the other four tires and I saw white smoke coming from the car. I thought I burned the esc but thankfully it was just dumb stupid chinese engineering again. I cycled the battery only once with a bulb, the timing was 7.5 degrees, 16T pinion, set on aggressive (2nd highest)..so it is a product defect (stupid one).
The on/off switch is actually a circuit breaker with 1mm wires for a system that has 60A/380A burst capability..what morons. No wonder they needed Clinton to give them secret info to launch missles w/o them crashing back in their faces.
I'm going to email them for their own sake and solder the connection directly, Ill just plug/unplug the battery which should work for programming too later..
My mrc charger pooped so I put the batteries in the fridge, I had enough. See you guys in a few months? lol I'll still reply to this topic.
#218
NY
Well it is now because apparently it doesn't work if you leave the switch on the whole time. These people are just idiots. How can you use a circuit breaker type switch on thin wires in a circuit that can pull so much current? Maybe they don't understand basic electrical laws.
I wouldn't buy anything like an ESC from china anymore cause they are stupid and don't test their products to their specs.
#219
My Feedback: (7)
I am sorry to hear that. We have redesigned the ESC completely, it now does have a on/off switch and a housing which is a lot smaller.... look here http://www.thiedemann-international....-1-10-CAR.html
Best regards,
Michael
Best regards,
Michael
"Fool me once, shame on you. Fool me twice, shame on me."
This is exactly why I go with reputable companies like Novak, LRP, or Castle Creations. The ultra low price tag is never worth the risk.
#220
I love that site it's like "price only available to registered merchants". It's like they expect everyone else to order on faith that the price will be good enough.
Also the switch, I don't think that's as much an issue as the other things. I can't think of an ESC out there today where the switch is a true on/off switch. Making it a true on/off switch would hurt the ESC's peformance. In most cases the switch is just going to the shutdown line on the BEC (which also powers the micro). That's why everyone will tell you, don't think the ESC won't continue to drain the battery even when switched off. But the switch does not have to carry any real amount of current at all.
What they probably did was the even funkier thing, if they are using a BEC that doesn't have a shutdown pin (many of the TO-220's don't in order to have only 3 pins) they might have just run the switch right to the micro and used that edge (debounced) to tell the micro to power up all the other circuitry. So if you plug in the battery with the switch already on, the micro won't ever see an edge (off-to-on) on that switch, and will just sit there. It's a quirky way to write firmware, there's no reason you couldn't just level-sample that switch, but you get these firmware guys who think they are the best and won't listen to others or follow common-rhetorical ways of doing things and you end up with some of the strangely coded firmware that's out there irl.
#221
ORIGINAL: Kitsune
How's that old saying go?
Best regards,
Michael
Best regards,
Michael
yes, thats actually quite true. We have exchanged the ESCs if there were any problems, without exception. The new ESC is made in Taiwan, btw. not in China. I am afraid that the new ESC is state of the art. Actually the price difference between a "good" and a "bad" ESC is not quite high, in terms for production. You may save app. 10% in cost.
We are not supplying the old ESC series anymore.
Best regards,
Michael
Modellfun Team
www.modellfun.com
#222
ORIGINAL: Access
actually this website is our ordering portal for our resellers all over the world. Its not kind-a-webshop, it doesnt calculate freight, we use it as an interactive catalogue. The prices are for wholesale quantities, so there is no use to display those publicly. If you do live in a region where you can´t get hold of those products, we are happy to quote you a retail price for it on request.
The on-off switch is actually not powering down the system entirely. The CPU thus is powered off, the only thing which slowly drains your battery are leakage currents from the capacitors and some DS-leakage currents, which are quite small, but, they will ruin a lipo if stored over some time.
Acutally helicopter/airplane ESCs do not have switches at all, it is a kind of a security measure for RC cars. It is not actually necessary, but in some stage it comes kind of handy, as mostly the switches are easily accessible without removing the canopy of the car.
In case of any questions, please feel free to ask.
Best regards,
Michael
Modellfun Team
www.modellfun.com
#223
ORIGINAL: Kitsune
Best regards,
Michael
Best regards,
Michael
I would be scared to waste money on something so cheap looking. Ebay is plagued with this stuff. A guy at one of the tracks I visit bought one
of those exceed nitro 1/10 buggies off ebay, it just looked like a cheaply made car. He couldnt even get it started.
The electric stuff is probably no different. Like those tenergy "no name cell" batteries I heard wasnt that good either.
#224
NY
The tenergy Propel batteries are great...but of course they have to come with bootleg Deans connectors that are larger than spec and the other versions (non propel) are crap.
What pisses me off is that it seems from hobbywing their repair service fee is free for 120days under warranty and they pay for shipment to you and even out of warranty their service charge is at most $20 if it is repairable but of course THEY HAVENT EMAILED ME BACK! I'm going to raise hell on everywhere rc if they dont reply and satisfy me.
Power of the internet baby invented BY AMERICANS.
#225
Hi,
our new ESC/Motor combo is on sale now, please check it at http://cgi.ebay.com/ws/eBayISAPI.dll...m=330262546981
This combo is suitable for 1:10 cars using 540 size motors.
Best regards,
Michael
Modellfun Team
www.modellfun.com
Best regards,
Michael
Modellfun Team
www.modellfun.com
