sb 977
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> MRC Charger Product Support (i.e. Super Brain, etc) >> sb 977
Page: [1]
Login
sb 977 - 12/29/2007 2:56:52 AM
timmaay
Status: offline
i reciently purchased a 977 and have had problems right off the back. i cannot get the discharge to work properly. i tried 3 different packs and they all do the same thing: the charger will start the discharge sequence (2 amps, 30mv, 6 cell, 4200mah) at 7+ volts, discharge the first cell then shut off after 10-15 mins still showing 6+ volts. start the sequence the again and stops after 1 minute with no change. am i doing something wrong, or is there a problem?
       Post #: 1
RE: sb 977 - 12/29/2007 3:50:00 AM
guver
Status: offline
All cells in a pack are being discharged at the same time and if the voltage is 6.?? volts then the pack is considered empty. Restarting will only go for another minute as you have observed.
Hopefuly the packs were'nt full, right? It sounds like they were empty.
_____________________________
you hear that silence?
(in reply to timmaay)
       Post #: 2
RE: sb 977 - 12/29/2007 4:24:49 AM
timmaay
Status: offline
no, when i started the voltage was around mid to high 7's. when it was done discharging, it said it discharged about 600-700 mah, mid to low 6's, and then read it as a 5 cell.
(in reply to guver)
       Post #: 3
RE: sb 977 - 12/29/2007 4:56:03 AM
guver
Status: offline
That sounds normal to me.
       Post #: 4
RE: sb 977 - 12/29/2007 6:13:07 AM
timmaay
Status: offline
quote:
ORIGINAL: guver
how is that normal? shouldn't the voltage go down to nearly nothing, and the discharged mah should be higher as well? not saying you are not right, but it doesn't sound normal to me. thanks for you input though, you are very helpful!!!!!!
(in reply to guver)
       Post #: 5
RE: sb 977 - 12/29/2007 6:58:32 AM
guver
Status: offline
No, it will discharge to maybe 6 volts or just a touch under 6 volts. You may be able to fool it quickly into thinking it's a 5 cell battery and then it may go down t less than 5 volts.
I'm not clear, were the batts full? anyways, if they were then they should show 4000 or more mah, but yours seemed to have only 600-700 OR a 1 bad cell perhaps.
       Post #: 6
RE: sb 977 - 12/29/2007 12:53:58 PM
timmaay
Status: offline
quote:
ORIGINAL: guver
yes the batts were full. the thing i'm still confused about is that the charger did the samething on three different 6-cell packs.
(in reply to guver)
       Post #: 7
RE: sb 977 - 12/29/2007 4:12:02 PM
guver
Status: offline
If they were full then they should hold over 6 volts for the whole 4000 mah and have a bad cell/connection.
       Post #: 8
RE: sb 977 - 12/29/2007 4:12:35 PM
Silent-AV8R
Status: offline
NiMH cells are considered fully discharged at 0.9 to 1 volt per cell. For a 6 cell pack this is 5.4 to 6 volts.
Lithium cells are fully discharged at 3 volts per cell. Going below either voltage is bad for the cells and in the case of lithium may harm them to the point of rendering them useless.
Reality is Subjective. At least that's what I think.
       Post #: 9
RE: sb 977 - 12/30/2007 1:06:54 AM
timmaay
Status: offline
i forgot that .9v was considered dead, and didn't do the math. thanks for the help!!!
(in reply to Silent-AV8R)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
