RE: Another Blue Angel build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Another Blue Angel build
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Another Blue Angel build - 4/28/2008 1:50:26 AM
dhal22
Status: offline
I have been away from the project for a few days but something that stumped me was how to check the formers that had to be hand drawn and cut out. so i glued in a few that i was sure of and flipped the fuse over to check the others that i have created. those appear to work just fine. the top piece of balsa is just being used as a straight edge that will stand up for photos
David
Click to see fullsize image.
Click for fullsize
< Message edited by dhal22 -- 4/28/2008 1:51:53 AM >
(in reply to dhal22)
       Post #: 26
RE: Another Blue Angel build - 4/28/2008 2:28:15 PM
rghalcomb
Status: offline
Hey Dave, Keep those pictures coming. Forget working for a living and those two kids and wifeget back to building the BA. She'll understand, mine does. You can fly yer old stuff anytime.
       Post #: 27
RE: Another Blue Angel build - 4/29/2008 9:33:49 AM
dhal22
Status: offline
unfortunately a deal for a nib OS .61 SF - pump engine with a nib OS header and OS pipe fell through this weekend. due to some email snafus the seller did not get my agreement to buy the package and sold it to someone else. man i wanted that engine!
david
(in reply to rghalcomb)
       Post #: 28
RE: Another Blue Angel build - 5/12/2008 3:22:57 AM
dhal22
Status: offline
finally got a weekend to spend some time on the build. the 2 top side fuse pieces were a difficult installation. the sides had to be leaned inwards as they mated to the formers from back to front. with lots of tape, some clamps and even a couple of screws i got them glued down. the top piece was comparatively easy. as with my king kobra build and other blue angel builds i installed an empty pushrod tube for my receiver antennae wire before i glued the top piece down. i was so excited about making some more progress i started some rough sanding of the sides before i glued the top piece on. common sense says there will be plenty of time later for sanding.
with plans of using a pumped .61 SF i soon realized that 8178's (or Howard Engineering's) method of installing a fuel tank is a great way to give the fuel lines a little bit of room. pushing the round cap of a tank through the 7/8" firewall hole i drilled left no room for tubing between the pump end of the engine and the fuel tubes.
david
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: Another Blue Angel build - 5/17/2008 1:49:45 PM
dhal22
Status: offline
Now that's what i'm talking about!!!
David
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 30
RE: Another Blue Angel build - 5/17/2008 1:54:20 PM
dhal22
Status: offline
i also have a fuse progress photo here. some basic shaping has been done but the most difficult shaping phases are still ahead.
david
Click for fullsize
       Post #: 31
RE: Another Blue Angel build - 5/17/2008 2:04:31 PM
rghalcomb
Status: offline
Looking good Dave.
       Post #: 32
RE: Another Blue Angel build - 5/17/2008 2:16:51 PM
rainedave
Status: online
Looks great Dave. I didn't know you could buy an OS muffler with a J'Tec Snuffler already attached. That is a Snuffler, correct? I put one on an old Max-H .40 and it really cuts down on the objectionable sound.
David
Click for fullsize
       Post #: 33
RE: Another Blue Angel build - 5/17/2008 2:44:10 PM
dhal22
Status: offline
the muffler came with the engine purchase. it is a very large muffler. i have no knowledge of the performance of the muffler so i posted it along with the other photos hoping for some expert comments. the engine also came with a jtec engine mount that has an anti vibration bolting assembly. again i have no idea if that is anything worth using.
thx, david
(in reply to rainedave)
       Post #: 34
RE: Another Blue Angel build - 5/17/2008 3:05:55 PM
Atlanta 60
Status: offline
Fantastic Dave!!!
That engine is too Kewl!!
Excellent...
Chuck
_____________________________
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
       Post #: 35
RE: Another Blue Angel build - 5/17/2008 4:27:08 PM
8178
Status: offline
Great news on the engine and keep the posts coming on the build! Great progress.
Builder and flyer of high performance acrobatic R/C aircraft and a proud member of VR/CS.
Made in China = no sale!
(in reply to Atlanta 60)
       Post #: 36
RE: Another Blue Angel build - 5/17/2008 5:21:20 PM
dhal22
Status: offline
i may be a rookie at building but i really enjoy it. thx for the comments guys.
david
(in reply to 8178)
       Post #: 37
RE: Another Blue Angel build - 5/19/2008 4:11:26 AM
dhal22
Status: offline
moving into the more difficult shaping stages of the fuse, i've dug into my national balsa order for some of the balsa blocks i ordered. the blocks feel way to heavy/hard to use, although i've done some cutting and shaping of some pieces. i have contacted national balsa about the density/weight and await their reply. i will probably just reorder the blocks in contest grade weight. it's time to place a misc. parts order with tower also, so maybe i will have the blocks included in that order.
david
       Post #: 38
RE: Another Blue Angel build - 6/1/2008 9:43:12 PM
dhal22
Status: offline
progress is slow, mostly due to inability to actually work on the project and it's flying season . lots of tracings have to be done and this weekend i did get the firewall, tank floor and a nose ring glued in.
david
Click for fullsize
Click for fullsize
Click for fullsize
