Steve Steinbring
FL, USA Status: online
Know the feeling! Put a 60 sized Sukhoi in the dirt on takeoff Sunday afternoon. It was getting real windy, with what was to be the proverbial "Last Flight" of the day. The airplane came off the ground quickly rolled about 90 degrees of bank to the left to my surprise. I corrected a wee bit too much and too quickly! Almost completely rolled the airplane to the right but didn't quite have enough altitude to fly it through. Found out I had forgotten to put the ailerons on low rate so I simply over controlled the airplane. The wind or no wind I normally should have been able to handle that situation, but I set myself up for crash. Anyway its now stripped down, starting to put the fuselage back together, the wing suffered almost no damage. Should have it flying pretty soon! Good luck with your rebuild, with your mods it should fly even better
