frankeldan
CT, USA Status: offline
quote:
ORIGINAL: lill will are you using a dx-7 radio if so how did you slave aux 2 to the throttle thanks Will, It was pretty easy. I'm in work so I don't have the radio in front of me, but you need to use mix 6 or 6. Those are the only ones that control aux2. Master = thottle slave = aux 2 set the hi and low limits on that screen, make the aux 2 active with the switch. I also think you have to go into the advanced menu and enable aux2 I'll check when I get home but it wan't that big of a deal to set up. Mike McConville has a nice how to on setting up aux channels for Spekrum.. just search on it in these forums. I started up the ZDZ80 this weekend , so next is to test out the smoke system. Anybody else running smoke on the Edge here? Later, Dan
