RE: OUTLAW from EXTREME FLIGHT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Lanier Prediator 500 (II) - RTF
Seller:  stuk_at_work
Details:   $150.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: OUTLAW from EXTREME FLIGHT
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: OUTLAW from EXTREME FLIGHT - 10/6/2008 5:41 PM
RobertV
Score: 100
Last Login: 6/20/2013
Status: offline
2008 RDRC Fly-for-Tots OUTLAW INVASION
Well, the Outlaw Invasion at the 2008 RDRC Fly-for-Tots event in Raleigh, NC was a huge hit! Team Outlaw pilots Larry Lewis, Jay Benson, and I were joined by 15 other Outlaw drivers on Saturday for a wild and fun flight! We behaved a little better than normal for this particular flight in the interest of crowd safety so although there were a couple of casualties, there were no midairs. And the spectators loved it! So the new record for Outlaws being flown at once now stands at 18. And records are made to be broken!
Thanks goes out to Chris Hinson at Extreme Flight RC for providing the cool commemorative T-shirts for all the participants. Good stuff!
Here's the list of participants as pictured in the first photo (click on any picture twice after it loads for max resolution):
Front Row (L to R) : Michael Hollowell, Chris Mulcahy, Larry Lewis, Jay Benson, Steve Miller, Wes Ryman, Andy Thompson, Nate Quan, Tee James
Back Row (L to R) : Elton Fairless, Dustin Hedrick, Josh Matthews, Robert Vess, David Hayes, Nelson Phillips, Nick Baxter, Josh Bunn, Kenny Tillman
Be ready when you are called upon for the next "wave"........
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Vess Propellers
Team JR
Hide Signatures
(in reply to Strykaas)
       Post #: 376
RE: OUTLAW from EXTREME FLIGHT - 10/6/2008 7:42 PM
bob27s
Score: 105
Last Login: 5/7/2013
Status: offline
That looks like it was a real blast there Bob !!
Thanks for posting the photos
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
(in reply to RobertV)
       Post #: 377
RE: OUTLAW from EXTREME FLIGHT - 10/6/2008 10:20 PM
Strykaas
Score: 123
Last Login: 6/13/2013
Status: offline
Nice Robert. Any video of the event yet ?
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
(in reply to bob27s)
       Post #: 378
RE: OUTLAW from EXTREME FLIGHT - 10/7/2008 1:01 AM
RobertV
Score: 100
Status: offline
There is some video in the "Flight Pass" section of www.higherplaneproductions.com that requires you to be a paid member. And then Chris Hockaday posted a short video (that was actually from Sunday and not the 18 plane flight) at: http://vimeo.com/1816280
Vess Propellers
Team JR
Hide Signatures
       Post #: 379
RE: OUTLAW from EXTREME FLIGHT - 10/7/2008 1:22 AM
Strykaas
Score: 123
Status: offline
OK thanks.
ProBro #2077
Hide Signatures
       Post #: 380
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 3:50 AM
chrome350
Score: 100
Last Login: 6/17/2013
Status: offline
I am trying to program elevons on an Outlaw using the 6AXS. I've programed elevons before but I am having a problem that I can't figure out.
I have everything mechanically setup as close as possible to get the 1 1/4" throws that I need on high rates.. I get 1 1/4" when I use up or down elevator and 1 1/4" if I use left or right ailerons. The problem is if I put the stick to one of the corners like full up elevator and full left aileron, I get more than the original 1 1/4" of travel and the servo arm cant move any further. On low rates it's not a problem. I've tried setting the ATV's but it doesn't help. Any suggestions ??
Larry
Hide Signatures
       Post #: 381
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 3:56 AM
evan-RCU
Score: 105
Last Login: 6/18/2013
Status: offline
UUUUhhhhhh this is normal, what are you asking?
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
Hide Signatures
(in reply to chrome350)
       Post #: 382
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 10:02 AM
chrome350
Score: 100
Status: offline
If I have 45 deg. of aileron and 45 deg. of elevator, the servo is trying to push the elevon past 45 deg. when the stick is in the corner. The elevon can't go past 45 deg because of the hinges. My question is what do the instructions mean when they say 45 degrees on the elevons? What are you suppose to measure? Do you measure the elevator, the aileron. or the deflection with the stick in the corner?
On low rates, I have 15 deg. on the elevator and 15 deg. on the ailerons. If I put the stick in the corner, I have about 30 deg. on one of the elevons and the other is neutral. That is how I understand it is suppose to work. However, if I have 45 deg. on the elevator and 45 deg. on the ailerons, the elevon would want to move to 90 deg. if the stick is pushed into the corner and it can't.
I know there is a simple answer, since there are so many Outlaws out there. I think I'm just having a brain fart.
If it's easier to explain over the phone, please PM me and I can call you or you can call me.
Any help would be greatly appreciated.
Larry
Hide Signatures
(in reply to evan-RCU)
       Post #: 383
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 2:33 PM
Strykaas
Score: 123
Status: offline
Note that an elevon mechanical mixing device would have the same effect .
ProBro #2077
Hide Signatures
       Post #: 384
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 8:10 PM
evan-RCU
Score: 105
Status: offline
quote:
ORIGINAL: chrome350
Larry
Larry this is all normal. The only way not to bind the servo with the stick in the corner is to reduce throws. Since you really want a screaming roll rate and the Outlaw doesn't really do anything special with elevator (you can get it to do some funky flips though) I suggest that on high rates you reduce the elevator throw a bit.
You'll also note when you put the stick in the corner the other elevon goes close to centered. On my scratch built Outlaws I make the elevons so they will deflect more than 45deg. But even then they bind with the stick in the corner. Use good servos, I had a servo go bad from binding because of this. Also you'll find the oOutlaw has a great roll rate and you'll be doing lots of rolls, it doesn't really do anything special in the loop department. Snaps and flat spins are great so you will be burying the sticks into the corners. So now that you know you'll be binding the servo you'll be more apt to limit the time you have the servo in bind and heating up....
Hide Signatures
       Post #: 385
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 9:23 PM
LeeHop
Score: 100
Last Login: 4/2/2010
Status: offline
Some radios seem to be smarter than others with respect to this.
See Limiting elevon travel
Hide Signatures
       Post #: 386
RE: OUTLAW from EXTREME FLIGHT - 10/26/2008 10:06 PM
robert92679
Score: 100
Last Login: 7/27/2011
Status: offline
This is normal when full travel is set to full up/down and full right/left. When the stick is in the corner you can over drive the servos. A solution is to limit travel so it is only full in the corners. Another suggestion is to use a 'cyclic ring'. This is a plastic ring installed on the radio that limits physical stick travel to a circle around the middle. It is commonly used by heli flyers on the cyclic (right) stick, hence the name.
Hide Signatures
(in reply to LeeHop)
       Post #: 387
RE: OUTLAW from EXTREME FLIGHT - 10/27/2008 9:41 AM
chrome350
Score: 100
Status: offline
Thanks for the help guys.
Larry
Hide Signatures
(in reply to robert92679)
       Post #: 388
RE: OUTLAW from EXTREME FLIGHT - 10/28/2008 12:13 PM
C_Roundy
Score: 110
Last Login: 4/9/2013
Status: offline
Short of going with a shorter connection point at the servo, the ATV's do not only "help" but more precisely they are exactly what you need, to limit servo travel to stop overdriving your end points with the sticks in the corner.
Overdriving a servo (or linkage) mechanical endpoint is the ultimate recipe for in flight failure.
< Message edited by C_Roundy -- 10/28/2008 12:24 PM >
Carbon is groovy man...
Hide Signatures
       Post #: 389
RE: OUTLAW from EXTREME FLIGHT - 10/29/2008 2:13 AM
Strykaas
Score: 123
Status: offline
Couldn't agree more...
ProBro #2077
Hide Signatures
(in reply to C_Roundy)
       Post #: 390
RE: OUTLAW from EXTREME FLIGHT - 1/4/2009 5:05 AM
Always flying
Score: 100
Last Login: 5/14/2013
Status: offline
fellas'
would a rossi quikie .40 be to heavy for this outlaw?
mannyh
Think i Won''t!...................
Hide Signatures
       Post #: 391
RE: OUTLAW from EXTREME FLIGHT - 1/4/2009 6:56 AM
cmircman
Score: 100
Last Login: 10/29/2012
Status: offline
I do not know much about the rossi but if it is the same weight as any other 40 I would say yes as these build nose heavy.
Rich
Never take life to serriously. You will never get out alive!
Rever Bro #195
Hide Signatures
(in reply to Always flying)
       Post #: 392
RE: OUTLAW from EXTREME FLIGHT - 1/4/2009 7:48 AM
Petrovsky
Score: 100
Status: offline
quote:
ORIGINAL: Always flying
fellas'
mannyh
The Rossi 40 is a powerful engine however to my knowledge is the heaviest around so would not be advisable for the Outlaw.
P
Tracto Allergicus
Hide Signatures
       Post #: 393
RE: OUTLAW from EXTREME FLIGHT - 1/5/2009 12:15 AM
Always flying
Score: 100
Status: offline
allright...now looking for a webra .36
Hide Signatures
(in reply to Petrovsky)
       Post #: 394
RE: OUTLAW from EXTREME FLIGHT - 1/5/2009 2:03 AM
gofastz
Score: 100
Last Login: 9/24/2009
Status: offline
Swift Electronics will carry the 36 webra.....I think it's $136 shipped.....Cliff passed away a few months ago but, Fay is keeping the torch burning.....You will not be disappointed with them or their service.....I used the 36 webra on my outlaw also.....9x7 APC will give you speeds in the 140mph range.....Gofastz
E-mail swift@mts.net or cswartz@mts.net
FAX 204 944 0170
Phone 204 885 1860
< Message edited by gofastz -- 1/5/2009 2:06 AM >
Hide Signatures
       Post #: 395
RE: OUTLAW from EXTREME FLIGHT - 1/5/2009 4:56 AM
Always flying
Score: 100
Status: offline
Gofastz,
Thanks for the info!...will give then a call tomorrow!
also sending you a pm
mannyh
Hide Signatures
(in reply to gofastz)
       Post #: 396
RE: OUTLAW from EXTREME FLIGHT - 1/6/2009 6:49 PM
George C
Score: 100
Last Login: 6/1/2013
Status: offline
Installing a Rossi 40 is doable but not advisable. I did it with a 53. I managed to balance the plane by placing the batteries and 160 gr of lead in a hatch in front of the trailing edge. You will have to split the engine mount in half so that the motor can fit. I'm not sure it is worth the effort though and the plane won't go any faster than with a 36. Mine showed 197 kph on the radar with an apc 9x9. I think mainly due to the thick airfoil.
Hide Signatures
       Post #: 397
RE: OUTLAW from EXTREME FLIGHT - 1/11/2009 5:28 AM
drcspeed
Score: 100
Last Login: 8/30/2010
Status: offline
Here is a link to my Electric Outlaw. I am pulling 2000 Watts at 92 Amps on 6 cell 5000mah Lipo.
http://www.youtube.com/watch?v=egEWgocvuVo
Hide Signatures
(in reply to George C)
       Post #: 398
RE: OUTLAW from EXTREME FLIGHT - 1/11/2009 8:13 PM
Strykaas
Score: 123
Status: offline
So loud man ! Awesome. What is your setup ?
ProBro #2077
Hide Signatures
(in reply to drcspeed)
       Post #: 399
RE: OUTLAW from EXTREME FLIGHT - 1/11/2009 10:27 PM
freakingfast
Score: 118
Last Login: 2/28/2013
Status: offline
Fast and loud..........I realy like it!
Oooh eee oooh ah ah(the crowd) ting tang walla walla bing bang!(the plane crash)
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.172RCU1
