RE: OUTLAW from EXTREME FLIGHT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: OUTLAW from EXTREME FLIGHT
Page: <<   < prev  14 15 16 [17] 18 19 20 21 22 23   next >   >>
Login
RE: OUTLAW from EXTREME FLIGHT - 1/12/2009 3:57 AM
drcspeed
Score: 100
Last Login: 8/30/2010
Status: offline
The Brushless Outrunner motor I am using is a custom motor we have been developing for the Outlaw.
The motor is called the Outlaw and is special order only for info on it contact.
http://www.gobrushless.com/shop/
Thanks for the kind words.
Hide Signatures
(in reply to freakingfast)
       Post #: 401
RE: OUTLAW from EXTREME FLIGHT - 2/1/2010 4:33 AM
Menthol
Score: 100
Last Login: 7/25/2012
Status: offline
Hi, I am in the progress of building the ARF... and in the instructions it says to tape the hinges with some tape.... is this really needed? Trying to find the "blenderm" tape could be a issue for me.
_____________________________
"Eagles may soar, but weasels don''t get sucked into jet engines."
Hide Signatures
(in reply to Strykaas)
       Post #: 402
RE: OUTLAW from EXTREME FLIGHT - 2/1/2010 7:11 PM
nsmjim
Score: 100
Last Login: 3/1/2012
Status: offline
Hey Menthol - Blenderm tape can be found in the drugstore (usually much less than a hobby shop) in the medical section. It is a great idea to help reduce the chance of flutter. I've never fluttered an Outlaw and have owned a few, but they probably wouldn't last long with a flutter!
Blue Skies,
Jim
When flying low and inverted, remember down is up and up is expensive.
Hide Signatures
(in reply to Menthol)
       Post #: 403
RE: OUTLAW from EXTREME FLIGHT - 2/5/2010 3:11 AM
c/f
Score: 100
Last Login: 5/17/2013
Status: offline
My electrified Outlaw has been radar @ 169mph, strait level and 180MPH in an agressive dive.
I have a new manuever I call the funnel, start by going high as possible, then full throttle, 45deg aileron roll straight vertical dive, it goes so fast its a blurrrr and looks like a funnel coming down. pull out at tree top level, it will make you wet yourself and the crowds go wild.........
No tape on hingeline tape this past season, never a flutter...........
Fully expect to piledrive it or shread it at some point, its just to insane/violent of a manuever..................
Hide Signatures
(in reply to nsmjim)
       Post #: 404
RE: OUTLAW from EXTREME FLIGHT - 3/3/2010 8:29 PM
hiTmanhiT
Score: 125
Last Login: 3/24/2013
Status: offline
Im going to buy this soon.
Already got a Evolution .36NT for it. What prop-size do you recommend?
Anything else I should be aware of?
Hide Signatures
(in reply to c/f)
       Post #: 405
RE: OUTLAW from EXTREME FLIGHT - 3/4/2010 1:36 AM
Strykaas
Score: 123
Last Login: 5/24/2013
Status: offline
8x8 9x7
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
(in reply to hiTmanhiT)
       Post #: 406
RE: OUTLAW from EXTREME FLIGHT - 4/1/2010 11:16 PM
George C
Score: 100
Last Login: 5/23/2013
Status: offline
Hello everyone again.
I maidened my second outlaw last week with a jen 37 with a purple pipe from just engines.
I get 18,100 rpm running an 8x7 apc on 10% fuel. Does anyone else have any rpm numbers of this combo?
The engine came run in from just engines and runs very smoothly throughout the rpm range with no bad habits.
The needle valve is a bit sensitive but the engine is not hard to set up.
I already have a gallon through it. The plane is not what I would call super fast but can be a lot of fun and worry free mainly due to the engine's reliability, it only quits when it has run out of fuel.
Overall a much better combo than the old one with the rossi 53 on it.
Hide Signatures
       Post #: 407
RE: OUTLAW from EXTREME FLIGHT - 4/2/2010 2:03 AM
Strykaas
Score: 123
Status: offline
Nice combo George. Which version from Jen .37 is it ? Is it the ringed one or the ABC one ?
ProBro #2077
Hide Signatures
(in reply to George C)
       Post #: 408
RE: OUTLAW from EXTREME FLIGHT - 4/2/2010 9:00 PM
George C
Score: 100
Status: offline
It is the ringed one.
Does anyone else run on this combo so I can have some rpm numbers as reference?
Hide Signatures
       Post #: 409
RE: OUTLAW from EXTREME FLIGHT - 4/2/2010 10:03 PM
combatpigg
Score: 376
Status: offline
That's roughly what I get out of a OS.32...
Unless you're prepared to go through a tuning session, what you see is what you get anyway.
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
       Post #: 410
RE: OUTLAW from EXTREME FLIGHT - 4/21/2010 5:45 AM
Michelle Conkle
Score: 100
Last Login: 11/16/2012
Status: offline
Hello all,
I just received my Outlaw today. I'm thinking about buying a Jett .35 engine, but which type ABC or AAC? My plans on putting a OS 46VX-DF in this delta were derailed as the engine has a inline carb requiring modifications to the fire wall. I have the Orange / Checkered , which I will change to Red / Checkered. Hitec HS-7954 High Voltage servos will go on the control surfaces to handle all of those insane G-Forces.
Also, I will look forward in flying with FreakingFast at the field.
Hide Signatures
(in reply to combatpigg)
       Post #: 411
RE: OUTLAW from EXTREME FLIGHT - 4/21/2010 7:52 AM
freakingfast
Score: 118
Last Login: 2/28/2013
Status: offline
Hi Michelle
The DF engine is much too heavy and too thirsty for that frame. An OS 32 with Macs tuned pipe is plenty. For ultra performance and least cost, a Webra 36 with Macs tuned pipe may trump a Jett 35 on a red muffler, but the Jett 35 AAC on a Macs tuned pipe would be the ultimate in power AND longevity...at a cost.
The Webra is slightly lighter but the sleeve is not chromed .
The servos you want may be overkill, some good metal gear high speed servos in the upper recommended torque range is all you need and wont kill the small batteries too quickly.
With this plane, think light. Weight is your enemy if you want to do the stunts it was designed for. That orange/checkered is the best in my opinion for visibility.
Hope this helps
Karl
Oooh eee oooh ah ah(the crowd) ting tang walla walla bing bang!(the plane crash)
Hide Signatures
(in reply to Michelle Conkle)
       Post #: 412
RE: OUTLAW from EXTREME FLIGHT - 4/22/2010 2:10 AM
Michelle Conkle
Score: 100
Status: offline
Ordered a Jett .35 AAC from Jett Engineering today. Engine will arrive in 4 to 6 weeks, engines are back ordered.
Hide Signatures
       Post #: 413
RE: OUTLAW from EXTREME FLIGHT - 5/28/2010 5:21 PM
dotronix
Score: 100
Last Login: 8/8/2011
Status: offline
hello all,I just finished building my outlaw
,but the only thing i can't understand is the cg point,from where it starts,could anyone make a pic with the details on,wouldbe very much appreciated
greetings
Hide Signatures
       Post #: 414
RE: OUTLAW from EXTREME FLIGHT - 6/19/2010 9:17 AM
Mikecam
Score: 120
Last Login: 5/18/2013
Status: offline
Well after reading this whole thread I'd like to thank all who offered advice on how to get the most out of the outlaw. Been wanting one for a while and since I was ordering a 88" Yak the extra $20 for shipping for the outlaw was a no brainer. Hope to have the first of many flights tomorrow.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dotronix)
       Post #: 415
RE: OUTLAW from EXTREME FLIGHT - 6/21/2010 7:10 AM
freakingfast
Score: 118
Status: offline
That's a kick@$$ every thing. Color,engine and pipe, congrats!
Hide Signatures
(in reply to Mikecam)
       Post #: 416
RE: OUTLAW from EXTREME FLIGHT - 8/12/2010 10:20 AM
Team_Monkey
Score: 100
Status: offline
Gents, I have read through all of this thread and found a listing for a Webra Speed 36 on thEbay so I picked it up. Turns out it's the ringed 35.
The box says speed 36, the auction said 36, and I get the 35. OY! I just emailed the dude about it so we'll see if he has the right engine to swap out.
Should I press for a refund or is this a worthwile engine?
Will the ringed 35 still cook on a MACs tuned pipe?
I was fortunate to also pick up a pretuned pipe set for the OS 32 so that's what I'll be using. All told I'll have about $85 into the engine and pipe. The pipe was NIB and the engine looks really fresh.
What's this talk of low nitro for the Webra engines? I run 30% heli in my .46 size speed planes. Heli fuel just because that's the only thing the LHS stocks higher than 20%.
Thanks for any info.
Hide Signatures
       Post #: 417
RE: OUTLAW from EXTREME FLIGHT - 8/12/2010 4:20 PM
Rocketman612
Score: 105
Status: offline
quote:
ORIGINAL: Team_Monkey
Higher nitro fuels are an American addiction. Over in Europe nitro isn't as available so their engines ( Webra, Moki )are designed with higher compression and run best with 0 or 5% nitro. You will have to shim the engine to reduce compression if you want the engine to run well with higher nitro fuel as you can have preignition issues. I added a shim to my Webra 32 and she runs great on 15% Coolpower.
Pete
"Remember, all I''m offering is the truth, nothing more..."
Morpheus
Hide Signatures
(in reply to Team_Monkey)
       Post #: 418
RE: OUTLAW from EXTREME FLIGHT - 8/12/2010 6:21 PM
Team_Monkey
Score: 100
Status: offline
quote:
ORIGINAL: Rocketman612
Pete
Thanks for the info Pete.
Does anyone have a feel for if a shimmed engine on 15% is equivalent or superior to a non-shimmed running on 5%?
I can't find any info on it. I'd have to order a shim but also not fond of stocking another blend of fuel. Already have 15%, 30% and gasser fuel.
Does anyone have experience with a Webra 35?
Is it a revver engine or just a sport engine? I think I saw a post somewhere that freakinfast had one but I can't find it now.
**edit**
OK, just found this Heli 35 that looks to be the same except a different head. It says it's ok for 15-30% heli fuel so what gives? Not doubting you Pete, just wondering what could be different. It is a ringed engine too.
Hide Signatures
(in reply to Rocketman612)
       Post #: 419
RE: OUTLAW from EXTREME FLIGHT - 8/12/2010 9:38 PM
Rocketman612
Score: 105
Status: offline
**edit**
[/quote]
I believe the engine will run comparably if using the pipe. I like to keep one type of fuel (15% Coolpower ) and use it with all my engines both 2 and 4 strokes. So I set them to run well on it. Only exception are my YS engines they get 30% heli fuel.
Heli engines have a larger and heavier head for the heatsink because it's enclosed in the helicopter. It may have a different compression not sure. You don't want a heavier engine on an Outlaw. Suggest posting some of these technical qusetions in the Glow engine forum for great info.
pete
Morpheus
Hide Signatures
       Post #: 420
RE: OUTLAW from EXTREME FLIGHT - 9/3/2010 10:24 PM
Big Mike
Score: 100
Last Login: 4/15/2012
Status: offline
I was wondering if anyone has heard of using the OS 40la. I had one on an Avistar and it was a decent engine for a trainer. Then one day (this was about 7 years ago) I built a mousse can pipe for it and the humble little LA was transformed into a firebreathing brute. I'm not exagerating here, believe me. I've used many different pipes on different engines and have never seen such a transformation. It gained about 2500 rpm and the power on the up lines was impressive to say the least. The OS46LA (the 40 is no longer available) weighs 9.7 oz without muffler. Pretty close to the same as the OS35. The downside to this engine was that the life of the LA was really shortened. After 20-30 flights with the mousse can the engine started rattling a bit and eventually the power fell off too. These engines are not made to go like a bat out of hell I know and have bushings instead of ball bearings so this was to be expected I guess. Still, if a guy had one or several of these humble little engines laying around like I did and not likely to ever see the sky again in our lifetimes (with electrics dominating the future) I think it would be worth a try on an Outlaw. By the way I ran a APC 10-6 and it seemed to be under propped so I went with a 10-7 ( I think) and that was better. Maybe with the slick airframe of an outlaw a 9-10 might be worth trying....comments?
P.S. That little 40LA is still running and is on an old old early arf trainer that belongs to a friend. Yes it rattles a bit and has somehow lost its previous sleeper like vigor (kinda like me) but it still is dependable and serving a function.
Hide Signatures
       Post #: 421
RE: OUTLAW from EXTREME FLIGHT - 9/3/2010 11:12 PM
evan-RCU
Score: 105
Status: online
When the .35 came out ten years ago we couldn't get them in the states. I ordered two from Hong Kong. They are not revvers. They are GP motors and I bought them for comp fun flys that spin big low pitch props. I mounted the first and the thing never had any compression. I ran a gallon through it and it never got better so I sent the other back to Honk Kong. I still have the one and consider it a paper weight. Even if it worked it would not be anything like a Speed .32 or .36...
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
Hide Signatures
       Post #: 422
RE: OUTLAW from EXTREME FLIGHT - 9/7/2010 4:08 AM
wkfg
Score: 100
Last Login: 7/11/2012
Status: offline
Just to throw another option out there for what it's worth, Jerry L. Smith has been using the .37 heli engine on his the last couple seasons.
Hide Signatures
(in reply to evan-RCU)
       Post #: 423
RE: OUTLAW from EXTREME FLIGHT - 9/7/2010 10:11 PM
Team_Monkey
Score: 100
Status: offline
Thanks for the info guys.
I've got the engine, the pipe and the parts are cut out for my scratched version of an Outlaw type thing. Guess we'll see how it does.
No sense in just setting it aside and not using it. I don't expect it to be as fast as the real thing but it fits my budget and should be fast enough to keep me busy.
Who knows, maybe someday I'll have a REAL outlaw and the proper setup.
Hide Signatures
(in reply to wkfg)
       Post #: 424
RE: OUTLAW from EXTREME FLIGHT - 9/8/2010 1:02 AM
freakingfast
Score: 118
Status: offline
It's no Webra 36, but the 35 will be just fine on an Outlaw.That's what came on my J.S built Outlaw that I got used years ago. It's about equal to an OS 32 in power. The pipe you have is the one you need for it, but I think you will need a new header or mod the mount holes. I ran the same prop for both engines, a 9X6 APC if I remember correctly. The ring 35 will take a while to break-in till it gets full power. The engine has a longer stroke than the OS32 or Webra 36 and the 35 develops more vibration so use a GENUINE OS bubbless clunk and isolate the tank's aft end with real foam rubber and you should be fine. I can't speak for the heli Webra engines, but all of the Webra airplane engines I've had dislike anything over 10% and can't see a power gain between 5 and 10%.
Hide Signatures
       Post #: 425
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.156RCU1
