RE: OUTLAW from EXTREME FLIGHT    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: OUTLAW from EXTREME FLIGHT
Page: <<   < prev  14 15 16 17 18 19 [20] 21 22 23   next >   >>
Login
RE: OUTLAW from EXTREME FLIGHT - 8/19/2011 3:14 PM
F4U Corsair
Score: 125
Last Login: 5/8/2013
Status: offline
Picking up a use Outlaw, do you think the newer Magnum .25 XLS will fly it? That's the only engine in the .25-.36 size I have laying around (Open B Combat engine). If not, I'll look for something in the .32-.35 range. I know this is a speed wing, but do they fly a slow speeds well or drop like a rock? DG
_____________________________
Experience is something you aquire after you need it!
Hide Signatures
(in reply to poiyt)
       Post #: 476
RE: OUTLAW from EXTREME FLIGHT - 8/19/2011 7:16 PM
crispinchurch
Score: 100
Status: offline
25 too small unless really tuned up on a pipe
a light weigth 40 a lot of people  use
Hide Signatures
(in reply to F4U Corsair)
       Post #: 477
RE: OUTLAW from EXTREME FLIGHT - 8/20/2011 1:48 AM
evan-RCU
Score: 105
Last Login: 5/23/2013
Status: offline
The .25 on a pipe with a 8x6 or 8x7 will fly it nicely. It's what Jerry designed it for and also what the Extreme site says.
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
Hide Signatures
(in reply to crispinchurch)
       Post #: 478
RE: OUTLAW from EXTREME FLIGHT - 8/21/2011 3:39 PM
F4U Corsair
Score: 125
Status: offline
Ok, picked up the Outlaw. Next question, it's missing the alum piece that hangs off the motor mount to protect the needle valve and rudder servo. It has a Spektrum 6000 rudder servo and it hangs down (looks like it would break in a landing). What do you suggest as a replacement for the alum piece? Anyone else get creative with protecting the valve and servo? Still looking for a .32 or.36 engine, but will start with the Magnum 25 XLS , just weighed it and it's 335g with the stock muffler, 237g w/o muffler, will start out with a 9x4 or 8x6 APC, should turn about 14-15k rpms on the ground since it's broke it. If I add the mousse can pipe I might pickup 1-2k? DG
< Message edited by F4U Corsair -- 8/21/2011 6:56 PM >
Hide Signatures
(in reply to evan-RCU)
       Post #: 479
RE: OUTLAW from EXTREME FLIGHT - 8/21/2011 7:51 PM
crispinchurch
Score: 100
Status: offline
make a skid to replace the ali one balsa or plywood if you havnt got ali just check CG afterwoods and if your motor can turn prop that fast you should be ok
Hide Signatures
       Post #: 480
RE: OUTLAW from EXTREME FLIGHT - 8/21/2011 8:35 PM
evan-RCU
Score: 105
Status: offline
If I was home I could send you a pic. On the original we usually used non remote needle valves. if we use a newer motor with one we cut it off the backplate and lay it on top of the motor then you don't need the skid. Also on the original the rudder servo was in the body, on my ARF I mounted it across from the throttle servo just like the throttle servo is mounted. I also mounted my elevon servos so the arm exits the bottom like the original.
Start with the 8x6 and yes a mousse can will pick it up a bit or get a full pipe...
Hide Signatures
       Post #: 481
RE: OUTLAW from EXTREME FLIGHT - 8/22/2011 3:52 AM
F4U Corsair
Score: 125
Status: offline
Thanks guys for the suggestions, a buddy just offered me his used 40LA but I'm not sure if the size/power would offset the extra weight. I'll have to check the weight of just the 40LA compared to the Mag 25 XLS. I think I need a skid of some sort to at least protect the rudder servo. It's already mounted so I'll try the skid first, if that doesn't work, I'll look into having it come out the top. I'm going to either turn the remote hs needle or take it off and mount it behind the engine on the firewall to get it out of the way. Just ordered the battery and rx, can't wait to get it all mounted and ready to maiden. Thanks, DG
Hide Signatures
       Post #: 482
RE: OUTLAW from EXTREME FLIGHT - 8/22/2011 10:16 AM
crispinchurch
Score: 100
Status: offline
forget the la  bet if you tested it its way slower
the biggest waste of money in the rc world
Hide Signatures
       Post #: 483
RE: OUTLAW from EXTREME FLIGHT - 8/22/2011 3:32 PM
Pylonracr
Score: 105
Last Login: 5/24/2013
Status: offline
I agree on the LA, but there is a thread a ways back on "OS Mod" about a gentelman trying to increase the power of an LA40.  I told him not to do it, for obvious reasons, but someone else said you could get great power out of this motor.
I would not try, but to each his own.
Revver Brother #260
Hide Signatures
       Post #: 484
RE: OUTLAW from EXTREME FLIGHT - 11/9/2011 2:14 PM
Mustang Fever
Score: 112
Last Login: 5/22/2013
Status: offline
Started my own thread before I realized this one was available. Anyway, Outlaw E conversion. Rimfire 25/Flightpower 60/3300 4S/10x6 MAS E prop. Won't be the fastest (maybe 60-65mph) but will have way more thrust than it weighs and will be loads of fun.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Bob Hunt
Hide Signatures
(in reply to Pylonracr)
       Post #: 485
RE: OUTLAW from EXTREME FLIGHT - 11/9/2011 10:44 PM
Mustang Fever
Score: 112
Status: offline
Motor installation almost done. Just have to extend the "cowl" sheeting aft from where it ends to the opening for the deck hatch. I'll put a couple holes in that sheeting for air inlet (with scoops) and some outlet holes way back on the hatch.
Click for fullsize
Click for fullsize
Bob Hunt
Hide Signatures
(in reply to Mustang Fever)
       Post #: 486
RE: OUTLAW from EXTREME FLIGHT - 1/30/2012 11:57 PM
Rudeboy
Score: 100
Status: online
Decided to get back into the hobby after a few years of abscence.
Figured the Outlaw would be a good way to get some stick time again
And a cheap thrill at that too...
Ordered me a nice piped WEST .36 (rpm version) for power, I think it'll fit the plane and it's intended purposes nicely.
Added a couple of reasonably fast Graupner digital servos...from the vids I've seen, this thing can use some fast servos.
So now I have to wait until the end of the week for my stuff to arrive...if it all gets here on time, I could probably test fly this weekend (hopefully).
I'll add my 0.02 to the thread if I run into anything particular during the assembly...video will probably be posted on Youtube...
Revver Brother #33
...I think it needs more power...
Hide Signatures
       Post #: 487
RE: OUTLAW from EXTREME FLIGHT - 2/2/2012 12:36 AM
Rudeboy
Score: 100
Status: online
Could someone give me some dimensions for the stock tank supplied in the ARF...?
I'm thinking about installing a Bubble Jett tank but I don't know if the ones from my Q500 planes will fit in there...
Revver Brother #33
Hide Signatures
(in reply to Rudeboy)
       Post #: 488
RE: OUTLAW from EXTREME FLIGHT - 2/2/2012 5:56 PM
BiggerDanno
Score: 100
Last Login: 5/21/2013
Status: offline
The bubble jet is a tight fit. You will need to flatten the top of it for the cover to fit.
Hide Signatures
       Post #: 489
RE: OUTLAW from EXTREME FLIGHT - 2/10/2012 2:02 AM
Strykaas
Score: 123
Status: offline
Welcome back Rudeboy !
How is your ankle/leg ? Did you recover 100% ?
Are the wests back on track for good ?
ProBro #2077
http://image2-0.rcuniverse.com/e1/forum/upfiles/57402/Nl29490.jpg
Hide Signatures
(in reply to BiggerDanno)
       Post #: 490
RE: OUTLAW from EXTREME FLIGHT - 2/13/2012 11:46 PM
Rudeboy
Score: 100
Status: online
thx...
Well, not 100% really, my ankle is messed up...and it will only get worse with time unfortunately (massive osteoarthritis)... But I can still hop around a little ;-)
I ordered the Outlaw from 3 different shops that were supposed to have them in stock, but apparently stocks have just about dried up everywhere!
So I gave up on the Outlaw, and ordered me a Mini Velocity from Weston today. Let's hope that one actually shows up (FAST! ). Too bad, since I really had my mind set on an Outlaw...it has that extra dimension with the rudder...
If someone happens to know a shop that still has one...drop me a line ;-)
Revver Brother #33
Hide Signatures
(in reply to Strykaas)
       Post #: 491
RE: OUTLAW from EXTREME FLIGHT - 4/23/2012 4:23 PM
AllTheGoodNamesAreTaken
Score: 118
Status: offline
I "heard" Extreame Flight is going to get another batch, but who know's if/when that will take place. I just re-covered mine in Solartex. Paint is next.
Click for fullsize
Don''t just stand there, go get some glue!
Hide Signatures
       Post #: 492
RE: OUTLAW from EXTREME FLIGHT - 5/9/2012 11:22 PM
c/f
Score: 100
Last Login: 5/17/2013
Status: offline
Spent a week with Chris H. @ SEFF. He told me he has about 50 Outlaws coming in the second container due in a few weeks. He told me Outlaw sales have reduce to the point he has not put the resources in to due a full container any time soon. I suggest if you want one of the 50 you contact them to arrange. .02
Hide Signatures
(in reply to AllTheGoodNamesAreTaken)
       Post #: 493
RE: OUTLAW from EXTREME FLIGHT - 5/10/2012 2:22 AM
Mustang Fever
Score: 112
Status: offline
Got it finished some time ago, and it flies really great. The Rimfire 25 will pull it out of my hand in a vertical launch and it just climbs away. One of the prettiest airplanes I've ever seen in the air and loads of fun to fly. Smooth and graceful.
The 25 on a 4S 3300 is turning a 10x6 MAS E prop at 12,000 RPM on 45A. Good for a little over 70mph and 4+ plus thrust. I have yet to run the pack down to the warning setting on the telemetry, and it flies for a very long time.
Click for fullsize
Bob Hunt
Hide Signatures
(in reply to c/f)
       Post #: 494
RE: OUTLAW from EXTREME FLIGHT - 5/10/2012 6:52 AM
combatpigg
Score: 376
Status: offline
Real nice conversion Mr. Mustang..!!
Blatantly corrupt umpiring at Yankee Stadium is an American tradition
It''s just part of the game.
Hide Signatures
       Post #: 495
RE: OUTLAW from EXTREME FLIGHT - 8/20/2012 5:00 PM
sodbuster 1
Score: 105
Last Login: 4/6/2013
Status: offline
What's the best way to go for max speed and say a 5-6 minute flight using E power
Once you go Yak, you never go back......
EX Club Saito member # 610
Hide Signatures
(in reply to combatpigg)
       Post #: 496
RE: OUTLAW from EXTREME FLIGHT - 8/20/2012 7:19 PM
Mustang Fever
Score: 112
Status: offline
sodbuster:
I've been using Makus Muller's ecalc with great success. http://www.ecalc.ch/motorcalc_e.htm
His numbers have been so good that every time I complete an application, I send him fifteen bucks.
If you need any help with it, let me know.
Bob Hunt
Hide Signatures
(in reply to sodbuster 1)
       Post #: 497
RE: OUTLAW from EXTREME FLIGHT - 8/23/2012 8:15 PM
ChuckL
Score: 100
Status: offline
Extreme Flight has the Outlaw in stock, I just received an orange one and it looks really nice.
Hide Signatures
       Post #: 498
RE: OUTLAW from EXTREME FLIGHT - 8/23/2012 8:25 PM
sodbuster 1
Score: 105
Status: offline
quote:
ORIGINAL: Mustang Fever
sodbuster:
That would be a great help.
Tried using it but can't see where it will tell me what motor/ESC/Battery/prop I should be using short of trying a zillion and one different combos till I happen to find the right one.
I must be missing something here...
Hide Signatures
       Post #: 499
RE: OUTLAW from EXTREME FLIGHT - 8/23/2012 9:04 PM
sodbuster 1
Score: 105
Status: offline
quote:
ORIGINAL: ChuckL
What're you going to power it with?
I've got mine set-up with a Webra Speed .36 on a Macs tuned pipe. Screamingly fast. Sounds wicked.
Butttt since I'm leaving the glow nation I'm trying to figure out what to convert it to electrically.
Hide Signatures
(in reply to ChuckL)
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
