khodges
NC, USA Status: offline
Thanks, Chic. I am also planning to hide the flap linkage. I've been studying the angles involved to figure on how much leverage I'll lose, but with a 132 oz./in. servo operating each flap, I don't think it will matter. Roy's plans state for 45 degrees full deployment, but I'm going for the scale 60 degrees. While we're on this kind of subject, what servos did you use for all your surfaces? I've always been a Futaba man, so I'm sticking with them for this plane as well. This is what I'm looking at: Rudder, elevator and flaps---S9206. Std size, 2 ball bearings, coreless motor and metal gears, 132 oz./in. torque, 4.8V only Ailerons---S9402. Std size, 2 ball bearings, coreless motor, metal gears, 89 oz./in. at 4.8V Throttle--S3001 precision. good basic servo, plenty for a gas throttle. Too much, too little? I certainly would rather go the overkill route than not enough. I really don't feel a need for digitals, this isn't a high performance plane and don't need the speed or holding power. Oh, and the CD will go out in tomorrow's mail back to you, and I am including templates for #5 and #6 formers. I made a few notes on them and since you've already built one, you will see what other mods have to be made to the airfoiled root piece that glues inside the cabin. It will have to be notched at #4 to allow it to make the angle possible, and the cabin sides will also require a relief "kerf cut" along the same line, just down to the line of the kerf cut called for by the plans. What happens here is the top of the cabin just above the rear side window should make a more gradual curve, but the root area must make a sudden angle. I can see it in my mind, especially after looking at several of the shots on that CD, and I will post pictures and a detailed explanation when I get to that point.
< Message edited by khodges -- 1/20/2008 5:29:49 PM >
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
