RE: Building a TOP FLITE ELDER
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Building a TOP FLITE ELDER Page: <<   < prev  1 [2]
Login
RE: Building a TOP FLITE ELDER - 5/11/2008 1:09:50 PM
jdr43
Status: offline
Yes, cap strips go left and right, and top and bottom on the wing.
Jim R
_____________________________
AMA # 731132
Saito Club #510
(in reply to thibor)
       Post #: 26
RE: Building a TOP FLITE ELDER - 5/11/2008 8:39:40 PM
thibor
Status: offline
@ Jim R
Thanks for the advise!!
Will go forward as you said, I"ll keep the pics comming...
Phil
(in reply to jdr43)
       Post #: 27
RE: Building a TOP FLITE ELDER - 5/15/2008 2:38:57 PM
thibor
Status: offline
Hey,
I glued the cap strips top and bottom, left and right. Sanding them down to the correct shape was a blast. Just bought the sanding tools from great planes and they do one hell of a job
Especially the multi-contour sander was verry handy.
The stab now looks pretty nice and was a lot a fun. This is my first kit build and already I'm sure I will be building many more
Last night begon the rudder, hope to end it tonight.
Phil
       Post #: 28
RE: Building a TOP FLITE ELDER - 5/18/2008 7:41:08 PM
Intruder38
Status: offline
I am in the final assembly stage of building my Elder. To those of you who have completed the build, what did you use for the cross bracing on the rear fuselage? I am reluctant to go with the elastic cord because it will probably suck up the oil from the exhaust.
       Post #: 29
RE: Building a TOP FLITE ELDER - 5/18/2008 10:23:48 PM
jdr43
Status: offline
I have been using elastic cord and not having any problems with oil etc.
Jim R
Click to see fullsize image.
Click for fullsize
AMA # 731132
Saito Club #510
(in reply to Intruder38)
       Post #: 30
RE: Building a TOP FLITE ELDER - 5/18/2008 11:30:50 PM
Intruder38
Status: offline
Jim,
And how did you attach the cord at the corners ... CA + kicker?
(in reply to jdr43)
       Post #: 31
RE: Building a TOP FLITE ELDER - 5/19/2008 4:19:34 AM
jdr43
Status: offline
I put a piece of plastic 1/8 inch wide small tubing in each corner to run the cord thru and hit it with CA + Kicker
Jim R
AMA # 731132
Saito Club #510
       Post #: 32
RE: Building a TOP FLITE ELDER - 5/19/2008 5:53:01 PM
Intruder38
Status: offline
Thanks, Jim! I'm just about at that point now. Based on your comments, I do believe I will proceed with the elastic cord.
(in reply to jdr43)
       Post #: 33
RE: Building a TOP FLITE ELDER - 7/7/2008 10:41:12 AM
thibor
Status: offline
Hey,
Been out for a while...
I finished the stab and fin, I'm getting ready for the wing.
Any tips?
Phil
       Post #: 34
RE: Building a TOP FLITE ELDER - 8/19/2008 1:08:58 PM
thibor
Status: offline
Hey,
Been on holiday...
I have finished the 2 wing halves, now I'm going to fine-sand and then join the wing.
I'm having a lot of fun building this first kit, already looking for the next one
Any tips I need to know?
Phil
       Post #: 35
RE: Building a TOP FLITE ELDER - 8/19/2008 4:53:11 PM
Don41
Status: offline
quote:
ORIGINAL: Intruder38
Jim,
I'm presently rigging the fuselage. I used elastic thread but I drilled a 1/16th hole in the frame. Locked down by jamming a round toothpick in the hole then a drop of thin CA. I used the toothpick method just to counter any possible loss of strength in the frame.
Regards
       Post #: 36
Jump to:
