PylonWorld
NC, USA Status: offline
FYI... I had a little free time tonight, so I started shaping the left half of the H-1. I ran into a serious problem. I use a 1" belt sander for rough shaping. I had noticed that hand sanding the pink foam with 220 did not work well, and that it peels the surface, if it is smooth anyway. I had a 120 grit belt on the sander, and I though I would be smart and change to a finer belt, so that the amount of foam removed would be easier to handle. So I put on the Extra Fine 220 belt. As I started sanding the canopy area, with several inches of foam meeting the belt, the piece was yanked out of my hand. I resolved not to let that happen again, so I held on tight. It happened again. Then I started sanding some of the foam away from the tail. When I took it off the belt I noticed some dark streaks. The dark streaks turned out to be melted foam. It seems the finer the grit, the more heat generated. Be very careful when sanding pink foam, especially with a belt sander or disc sander. I tried some Tri-M-ite 150 paper, and it does not work well either. The only paper that seems good for shaping the pink foam is 150 wood sanding paper. I have used 320 wood paper for very fine sanding with no problem, but I think it was because of using a very light touch. 100 grit can be used, but be aware that it hunks away the foam, so leave room for final shaping with the 150.
_____________________________
Don Stegall RCPRO Chairman of the Board
