Torquestar
Joined: 12/20/2007 From: Merced, CA, USA Status: offline
I noticed this as well. I took the blades off and noticed that when I tighten down the screws into the feathering shaft that they bottom out before they tighten on the blade grips. It's kinda far away, so the grips have some room to float around a bit. I would assume some tolerance would be needed so the grips could rotate, but there seems to be an excessive amount of gap. You'll notice that in photos of the B400, the blades droop down at an angle from the head. I think this is unfortunately normal. I guess if I was better at heli's this might be a big concern, but since I'm just starting out I wouldn't know how a good heli is supposed to feel like. quote:
ORIGINAL: Wolfpackin fw190, quote:
The current plastic rotor head is a bit mushy. I just started noticing that the blade grips have some slop, play, in them. They move up and down a little when I lift the main blades up. Is this what you are talking about? Is it normal for this heli? I was about to take the blades off and see if the socket head cap screws that hold the grips on are loose or if the feathering shaft is bent. What do you think?
