bignuts181
Joined: 1/7/2008 From: melbournevictora, AUSTRALIA Status: offline
Hi guys one of the basic setups we do with all of our blade 400's (we have now set up over 140 of them) is to first of all reset the radio and reduce dual rates on all three functions to 70% dual rates and 10% expo on aileron and rudder, with 30% expo on rudder. Next up the throttle curve (for indoors) is set to 0, 47, 65, 65, 65, The pitch curve is set to 60, 67, 77, 82.5, 91.5 this gives you a nice progressive throtle and pitch curve that isn't flighty and so is good for a beginner. We also found the rudder was overthrowing from the factory, so we move the tail pitch/rudder linkage in one hole on the tail pitch/rudder servo. Hell I'm a low time heli pilot but even I can fly one of these inside the shop at work with these settings Finally we have also found the blade 400 benefits enormously from being fitted with Hitech HS 65hb's around the rotor head.....10 times easier to fly!!
