tatolazo
Joined: 7/7/2003 From: concepcion, CHILE Status: offline
HI: In our first IOMs we used the deck hatch with a raised edge to avoid water from coming in, but we couldn“t solve that. Finally we removed all and let the deck flush and started to use vinyl patches. They worked great. Also consider seriously the GWS 1T servo winch. from servohut.com. It is very cheap and you can achieve easyly a very good handling of the sails with this. I use to put the sheet line from the servo down to the back, near transom, and glue in a "U" shaped soft copper tube ( or you can burn it in your kitchen to softening) So the line goes over the deck and come back to the mast. with the winch fully closed i tie a swivel next to the exit of the line in the deck and from the main and jibe booms comes the lines to this swivell. So when putting all together I just open the swivell and place int the loop in the line from the sails. Then you move the stick full opossite to opening the sails and set the travel of sail booms with the dual rate or atv. if you are using a simple radio, you can just attach a scrap plastic with tape to limit the travel of the sail channel stick. This way you achieve maximum torque and minimum lines over and below the deck. As a famous modeller ( R/C aerobatic champion Quique Somenzini said to me once: "if IT is not in your model, it does not fail" The more gizmos you put in, the more Murphy chances..... I hope really have the time to shoew you some pictures. But i going home late and from this PC I can not load pictures. Keep up your good work. Tato Lazo
