RG-65 Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Sailboats >> RG-65 Build Page: [1] 2   next >   >>
Login
RG-65 Build - 1/3/2008 3:10:09 AM
ROADTOAD
Status: offline
This class of sailboats maybe the next growing class within the USA and Canada.
If you want to get in on it, send me a PM.
My current build is in progress
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: RG-65 Build - 1/6/2008 5:26:38 PM
ROADTOAD
Status: offline
Got some more time in on the hull
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ROADTOAD)
       Post #: 2
RE: RG-65 Build - 1/9/2008 3:35:25 AM
ROADTOAD
Status: offline
Fairing compound was spread over the hull to fill in any low spots and to get a real nice smooth even finish. A bit of sanding and it was ready for priming.
Did an inital priming of the hull today (not pictured). Looked for high and low spots. spent 15 minutes doing another overall sanding. Looks about as good as it's going to get. I'll give it one more priming before the hull is pulled from the jig. And get to work on a deck.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 3
RE: RG-65 Build - 1/9/2008 11:47:28 AM
tatolazo
Status: offline
Hi:
Great
This is a very exiting class of sailboats, cheap to build and easy to set up. No expensve hardware is needed.
Make sure you cut your sails from 30-40 microns polyester or from 1/2 oz. ripstop.
mast should be 6mm carbon spars ( 1/4" , some folks used 5mm and it bends a little too much, booms could be 3 or 4 mm carbon spars
keep your photos coming up!!!
       Post #: 4
RE: RG-65 Build - 1/10/2008 11:02:26 AM
ROADTOAD
Status: offline
Thank you for the useful info, it will come in handy!!
(in reply to tatolazo)
       Post #: 5
RE: RG-65 Build - 1/11/2008 1:14:41 AM
ROADTOAD
Status: offline
Just pulled the hull off the building jig
Click for fullsize
       Post #: 6
RE: RG-65 Build - 1/11/2008 12:37:42 PM
tatolazo
Status: offline
Hi:
It seems that you glued the bulkheads to the hull. It looks shiny like if some epoxy or laquer was applyed.
I did my IOM with ply bulks but i used some tape over the edge of the bulkheads so after i glued all the balsa spars that make the hull i was able to pull out all the bulkheads and the hull was totally empty inside, allowing space for mounting servos, and bulb box easily.
i would try to post some pictures.
keep up your good work!!!
Tato Lazo
       Post #: 7
RE: RG-65 Build - 1/12/2008 12:26:58 AM
ROADTOAD
Status: offline
I planked the hull using balsa, then epoxy coated the inside while still on the building jig.
This was done to strength and to make the hull rigid.
This hull is being built to be used as a plug.
A mold will be made from it so a number of hulls can be reproduced in fiberglass.
If it's great sailing boat, like to build a few more of this hull.
Happy sailing
       Post #: 8
RE: RG-65 Build - 1/13/2008 1:47:31 AM
ROADTOAD
Status: offline
Started on the deck today.
Click for fullsize
       Post #: 9
RE: RG-65 Build - 1/15/2008 2:18:11 AM
ROADTOAD
Status: offline
The deck has been attached so the edges could be flush sanded to match the hull edge. Then I will lower the rear cockpit section further into the hull. Still a fair amount of work to do....
The hull will measure 65cm when finished with bumper, 15cm beam width, 3cm waterline, 8.5cm total height from hull bottom to top of deck.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ROADTOAD -- 1/15/2008 10:58:12 AM >
       Post #: 10
RE: RG-65 Build - 2/11/2008 1:16:49 AM
ROADTOAD
Status: offline
Had a chance to get some of the deck done today, still needs more work....
Click for fullsize
Click for fullsize
       Post #: 11
RE: RG-65 Build - 2/29/2008 11:02:59 AM
ROADTOAD
Status: offline
Deck and hull have been board mounted and will be prepping to make a mold from them.
Click for fullsize
       Post #: 12
RE: RG-65 Build - 3/9/2008 10:16:07 PM
ROADTOAD
Status: offline
Looking forward to finishing off the plugs, just need some warm weather for priming and painting
Click for fullsize
Click for fullsize
       Post #: 13
RE: RG-65 Build - 3/26/2008 12:22:04 AM
ROADTOAD
Status: offline
Plugs almost ready for mold making
Click for fullsize
       Post #: 14
RE: RG-65 Build - 4/6/2008 11:13:30 PM
