AFSalmon
Joined: 5/24/2002 From: Beavercreek, OH, Status: offline
Outssider, There is no way that slight amount of curve will affect the overall length of the rib or alignment on the jigs. We are talking probably hundreds of an inch relative to overall length and spar locations. My recommendation is build per the instructions and weight the wing panels (per instructions) while you sheet. Also, the instructions recommend tack gluing the ribs to the jigs as you progress.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer Ohio Model Planes, Team OMP Captain
