nikg
I am trying to get an idea of the capacity and voltage numbers for some loose cells so I can construct some packs that are matched relatively well. I have many to test and i don't want to spend a month trying to get info on them. They are GP 3300's and I am form charging them 6 at a time at 210ma for 24 hrs. I then intend on taking them individually and discharging them to see what each cell reads for voltage and run time. Is discharging at 10A OK or should I go more like 5-6A? I know to get full capacity the cells should be cycled about 3-5 times, but this will take me 3-4 days for each 6 cells, and I don't want to spend that much time if I don't have to. I'm not exactly sure how battery chemistry works but here are my three theories. Let's say cell A shows 3000mah at 1.15v on the first discharge and cell B shows 2500mah at 1.12v on the first discharge. THEORY 1--- Both cell A and cell B continue to gain capacity (and voltage?) by 10% on second cycle, 5% on third and 2% on fourth cycle. Cell A thus gains more each time because it started at higher capacity (and voltage?). This leaves cell A having an even greater difference in capacity (and voltage?) than cell B from the first cycle, even though they both improve. THEORY 2--- Both cell A and cell B continue to gain capacity (and voltage?) in each cycle, but it is more linear. For instance, they both gain 200ma (and .02v?) on second cycle, both gain 100ma (and .01v?) on third cycle and so on. This still leaves cell A with more capacity and voltage than cell B, but the difference is the same as it was after the first cycle because they both improve in the same amounts. THEORY 3--- Both cell A and cell B continue to gain capacity (and voltage?), but the opposite of theory 1 occurs and cell B "catches up" to cell A by the third or fourth cycle. In the end they wind up having similar numbers. I guess what I'm really trying to ask is, are any of these theories correct?(I'm leaning towards theory 1 intuitively) Can I get decent comparative information from just one cycle, or must I run them through 2 or more? I'm really just looking to match them up relatively well compared to each other so the packs drain the cells evenly.
