Jeremy Sebens
IL, USA Status: offline
The airplanes are scored on several factors. A mission score is made up of the following formula: Difficulty Factor/(Mission time+assembly time+Rated Aircraft Cost) The assembly time is the time it takes the team to remove the airplane from a 1'X2'X4' box and assemble it into a flightworthy condition. The Rated Aircraft Cost (RAC) is based on a complicated formula involving the size, wieght, and propulsion system of the aircraft. Our aircraft has been designed to trade of between these requirements in the hopes of maximizing our score. It goes together quickly, has a moderately low RAC, and flies pretty quickly. Based on the new, improved flying qualities of the aircraft, I expect we'll do well at the competition. More later, but I've got to go fly it now! And it's not unconventional - just stubby. There's still an engine up front, a wing in the middle, and a tail in back - it's just the proportions that are odd. Please try not to criticize the design work of what I consider a talented group that it has been a privilege to work with unless you understand the (extremely complex) mission requirements. There is a very good reason that a Pilatus Porter (which our airplane vaguely resembles) looks different from an Extra 330L. Neither would perform the other's mission well.
