choppersrule
IN, USA Status: offline
Wolfpackin, Here's a copy of the binding below. An educated guess, is that EACH model number in the Tx, sends it's own specific code to the receiver and trains it to that code. Model 1 would have a code of say, "ABC" and model two, would have "KLM" as examples. So, with that thought. You would only have to rebind the Receiver when switching model numbers, what the heck, it doesn't take that long to do. Good luck, it would be fun to try and a new learning experience to boot. +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ "The AR6200 receiver must be bound to the transmitter before it will operate. Binding is the process of teaching the receiver the specific code of the transmitter so it will connect to that specific transmitter. Once bound, the receiver will only connect to the transmitter when the previously bound model memory is selected. If another model memory is selected, the receiver will not connect. This feature is called ModelMatchâ„¢ and prevents flying a model using the wrong model memory"" +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Dave / Choppersrule
_____________________________
Left skid low....
