RE: T34 build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: T34 build
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: T34 build - 2/10/2008 4:52:57 PM
YHR
Status: online
Yes those gear boxes look great. The low profile sure works well with the T-34. I have a SU 100 with the original drive. Once this starts giving me trouble, I know what i'll be putting in it!!!.
< Message edited by YHR -- 2/10/2008 4:57:41 PM >
(in reply to fv432)
       Post #: 26
RE: T34 build - 2/10/2008 6:16:10 PM
fv432
Status: offline
trust me YHR you won't regret it (unlike me with the metal gear upgrade )
_____________________________
1/25panther/jagdpanther 1xhl Tiger 2xhl Bulldog 1xT34 wsn 2xhl pz111 3xm26pershing 1x1/16 tam sherman
1xm46conv W.I.P
(in reply to YHR)
       Post #: 27
RE: T34 build - 2/10/2008 6:36:11 PM
Panther F
Status: offline
Nice work Rob. Looks pretty much like a bullet-proof set up!
Tamiya 38-cm Sturmmorser, M4 Sherman, M26A1 Pershing, M4A1E8 Sherman, TI, Panther, Jagdpanther, KT, WSN/Tamiya T34 & SU-85
(in reply to fv432)
       Post #: 28
RE: T34 build - 2/10/2008 6:43:21 PM
fv432
Status: offline
thanks for the encouragement guys Really happy with the way it turned out limited work and a lot of gains
the brass tube between the rear gears is a must
as those that have the T34 will now just how much play there is in there
1xm46conv W.I.P
(in reply to Panther F)
       Post #: 29
RE: T34 build - 2/11/2008 9:59:49 AM
The hussar
Status: offline
fv432 you know the ratio of this new gear box?
THX!
(in reply to fv432)
       Post #: 30
RE: T34 build - 2/11/2008 3:01:19 PM
fv432
Status: offline
ive heard a figure of 67:1 but not 100% on that
1xm46conv W.I.P
(in reply to The hussar)
       Post #: 31
RE: T34 build - 2/23/2008 12:41:10 AM
fv432
Status: offline
bit more done on the 34
wiring and boards in made a new antenna with thanks to PZRWEST
also noticed that whilst under power it's possible to speed these gearboxes up by moving the final gear to the position in the pic with the green outline in
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by fv432 -- 2/23/2008 12:43:34 AM >
1xm46conv W.I.P
(in reply to fv432)
       Post #: 32
RE: T34 build - 2/23/2008 7:54:27 AM
astroboycp
Status: offline
Wow I would like to mod my T34 with that gearbox too. Oh by the way, would like to know where did you order the metal spur gear from? I would like to put one onto the T34 shaft too and see if it increases the torque. I've tried to search for the ebay add which you gave but couldn't find the ebayer.
F a i l u r e i s t h e M o t h e r o f a l l S u c c e s
(in reply to fv432)
       Post #: 33
RE: T34 build - 2/23/2008 7:56:08 AM
astroboycp
Status: offline
Where can I order this from?
(in reply to fv432)
       Post #: 34
RE: T34 build - 2/23/2008 4:32:31 PM
fv432
Status: offline
the "spur" gear is from the metal upgrade set and the one i got was from the Blueslatesman of E-vil bay
unfortunatly the rest of the gears from the set are now useless
1xm46conv W.I.P
(in reply to astroboycp)
       Post #: 35
RE: T34 build - 2/23/2008 4:34:10 PM
fv432
Status: offline
quote:
ORIGINAL: astroboycp
this gear is actually from the Henlong metal gearbox on the final shaft which attaches to the sprocket
1xm46conv W.I.P
       Post #: 36
RE: T34 build - 2/23/2008 4:38:52 PM
YHR
Status: online
Yes, the plastic gear housing is just not up to the task of holding those metal gears all in place for the long term. The gear transplant will probably be required on my SU 100 one day. I believe in running them unitl failure though, and so far the SU 100 has stayed together. I still have the metal tracks on the shelf though, as I have been afraid to tax the stock gearbox with the addition of the metal tracks. Seems like once you go to metal tracks you better be prepared for things to start going wrong.
(in reply to fv432)
       Post #: 37
RE: T34 build - 2/23/2008 7:53:12 PM
fv432
Status: offline
I've popped 2 std gearboxes in mine (although they were being run on std car E.S.Cs)
which is why i went with the metal upgrade put that in but it still was noisey and the gears "floated" around so much decided enough was enough and went this route
1xm46conv W.I.P
(in reply to YHR)
       Post #: 38
RE: T34 build - 2/23/2008 10:36:57 PM
Panzerfaust77
Status: online
What make of tank is this? It looks similar to a Heng Long.
HL Tiger, HL Panzer III, HL Panzer IV
(in reply to fv432)
       Post #: 39
RE: T34 build - 2/23/2008 11:08:44 PM
fv432
Status: offline
It's the older non I/R T34 by wsn(WASAN)
1xm46conv W.I.P
(in reply to Panzerfaust77)
       Post #: 40
RE: T34 build - 2/24/2008 12:09:24 PM
wackywheelz
