Control Surface Deflection
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Control Surface Deflection Page: [1]
Login
Control Surface Deflection - 1/5/2008 1:55:41 AM
layback2
Status: offline
I could use some help on the Recommended Control Surface Deflection
Control Direction for a J3 cub 25 that had a not so good manual can someone fill this in in inches or close as it can be please thank you
mm in.
Elevator Up 30
Elevator Down 30
Rudder Both 35
Aileron Up 1.1
Aileron Down 1
CG 56-66
< Message edited by layback2 -- 1/5/2008 1:56:38 AM >
       Post #: 1
RE: Control Surface Deflection - 1/5/2008 3:32:22 AM
layback2
Status: offline
never mind i got the answer
30mm = 1.18"
35mm = 1.37"
1.1mm = .043"
1.0mm = .039"
56mm = 2.20"
66mm = 2.59"
(in reply to layback2)
       Post #: 2
RE: Control Surface Deflection - 1/5/2008 7:49:33 AM
combatpigg
Status: offline
The elevator and aileron throws look wacko.
_____________________________
Led Zeppelin is NOT "old fogie" music.
       Post #: 3
RE: Control Surface Deflection - 1/5/2008 1:31:08 PM
rainedave
Status: online
Yep, those don't look right at all!
Start with this:
Ailerons - 8° down; 10° up
Elevator - 12° each way
Rudder - about 20° or more
Be certain that you hook the push rods up to the innermost holes on the servo arms and the outermost holes on the control horns. Otherwise, your Cub will be twitchy in the air.
David
(in reply to combatpigg)
       Post #: 4
RE: Control Surface Deflection - 1/5/2008 4:09:18 PM
combatpigg
Status: offline
I've always wondered why a set of plans that took 8 hours to draw doesn't contain 15 minutes worth of detailed notes about how to set up the controls?
(in reply to rainedave)
       Post #: 5
RE: Control Surface Deflection - 1/5/2008 9:12:44 PM
layback2
Status: offline
Thanks for the help yes i wonder why any arf plane made has such a crummie Manual i have found other items on the plane that didnt make sence to me either.for one the engine crowl does not have any room to mount to the front of the fuse it slides over the engine mount and thats as far as it will go.the control rods set in a plactic tube then go in the tube even the worst arfs i have seen used a wooden rod and small short control rods with heat screnk over it.not this one i will replace the control rods to 56s anyway thanks
       Post #: 6
RE: Control Surface Deflection - 1/6/2008 12:44:18 AM
BMatthews
Status: offline
Those specs are more for 3D flying regarless of if they are degrees or mm's. Definetly wacko.
Bruce-
Proudly wasting balsa since 1965.
Free Flighters go that extra mile........
       Post #: 7
RE: Control Surface Deflection - 1/6/2008 3:25:44 AM
layback2
Status: offline
Well makes no sence to me why the same plane same size different maker will have a good manual and the setup for the controls be so different
This plane here is the eflight J3 cub 25 comes with a very good manual
Control Throws
The amount of control throw should be adjusted as closely
as possible using mechanical means, rather than making
large changes electronically at the radio. By moving the
position of the clevis at the control horn toward the outermost
hole, you will decrease the amount of control throw of the
control surface. Moving it toward the control surface will
increase the amount of throw. Moving the pushrod wire
at the servo arm will have the opposite effect: Moving it
closer to center will decrease throw, and away from center
will increase throw. Work with a combination of the two
to achieve the closest or exact control throws listed.
High Rate Low Rate
Aileron 3/4" up, 3/4" down 1/2" up, 1/2" down
Elevator 5/8" up, 5/8" down 3/8" up, 3/8" down
Rudder 1
3/8" right, 1
3/8" left 1" right, 1" right
Note: The above throws are a good starting
point for most flight conditions.
Exponential Settings
High Rate Low Rate
Aileron 20% 10%
Elevator 20% 10%
Rudder 20% 10%
Then you see the one i have from texasrcplanes
mm in.
Elevator Up 30
Elevator Down 30
Rudder Both 35
Aileron Up 1.1
Aileron Down 1
CG 56-66
same size plane same wing span like i said makes no sence to me at all
(in reply to BMatthews)
       Post #: 8
RE: Control Surface Deflection - 1/6/2008 3:37:13 AM
combatpigg
Status: offline
The E Flite settings look flyable, but 1/2 inch is still a lot of aileron. 1/4 inch of aileron will fly most 1/2A planes.
       Post #: 9
RE: Control Surface Deflection - 1/6/2008 3:46:42 AM
rainedave
Status: online
What the E-flight manual isn't telling you is that you lose resolution and leverage when you move the pushrods in on the control horns and out on the servo arms. This is very noticeable when flying the plane.
Start with the pushrods set up as I described in post #4 with your radio's EPA's set at 100% each way. Then, if you need more throw increase the EPA to greater than 100% first. Try to avoid moving the pushrods, but if you have to, do it at the control horn, not at the servo.
It is truly amazing how much better planes fly when you have maximum resolution. I've seen too many poor flying models that could be cured simply by attaching the pushrods the correct way.
David
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
