Put revs on and truggy went backwards????
Tower Hobbies
Logged in as Guest
  Printable Version
Tamiya Land Cruiser CR-01 Crawler w/ ESC - Kit
Seller:  sheograth
Details:   $300.00   |  11/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Put revs on and truggy went backwards????
Page: [1]
Login
Put revs on and truggy went backwards???? - 1/5/2008 12:31:07 PM
zs123
Status: offline
I started my buggy after like a month and when I got it started and let it warm up, so I took it outside a put revs on and the truggy went backwards and I don’t have reverse on it can any explain why this may of happened??
       Post #: 1
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:08:21 PM
Tweedybird
Status: offline
Your diffs are in backwards
happened to me at track one day after doing a diff oil change.
good idea to mark them when you take them out.
either that or you started your motor backwards.
which is also possible
TB
_____________________________
Run Your Engine, Don't Let Your Engine Run You!
*Love the smell of Nitro in the morning!*
-=RCUniverse.Com=-
When the cop pulls you over doing 160 mph, and asks if you knew how fast you were going say, "yep i had cruise control on".
(in reply to zs123)
       Post #: 2
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:17:40 PM
qaiz
Status: offline
LOL, how can you start your motor backwards.
I wanna try that.
Emirates Hobbies
Support your LHS.!
(in reply to Tweedybird)
       Post #: 3
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:22:20 PM
ttoks
Status: offline
i did it with my LRP... remember you can't put 8ight diffs in backwards... CLICKY, all you need to do it get your bump box to turn the engine over backwards.. mine miss fired though, started it with a hand held electric start.
< Message edited by ttoks -- 1/5/2008 1:23:48 PM >
when the cop pulls you up doing 234 km/h and asks if you knew how fast you were going, say "yep i had cruise control on
(in reply to qaiz)
       Post #: 4
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:22:35 PM
qaiz
Status: offline
My rotostart rotates towards the left, if I get it to rotate to the right, will it start backwards.?
Emirates Hobbies
Support your LHS.!
(in reply to qaiz)
       Post #: 5
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:25:00 PM
ttoks
Status: offline
if you put the OWB in backwards, if it's an external bearing.
(in reply to qaiz)
       Post #: 6
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:26:17 PM
Tweedybird
Status: offline
He's Running a buggy, which usually means starter box, you can easily start a motor backwards on a box, by spining the flywheel in the wrong direction.
TB
and unfortunately you can put the diffs in backwards on an LST lol
thats the truck it happened to me on.
-=RCUniverse.Com=-
(in reply to qaiz)
       Post #: 7
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:31:22 PM
qaiz
Status: offline
IM GONNA TRY THAT RIGHT NOW .
Always wished I had reverse lol, now I can have it permenantely.
It dosent do any serious damage does it.?
Emirates Hobbies
Support your LHS.!
       Post #: 8
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:36:07 PM
Tweedybird
Status: offline
I wouldn't recommend doing it on purpose...
-=RCUniverse.Com=-
(in reply to qaiz)
       Post #: 9
RE: Put revs on and truggy went backwards???? - 1/5/2008 1:38:23 PM
qaiz
Status: offline
Yeah not trying that, older bro said it was a stupid idea.
Could mess up the clutch.
And anyway, my truggy's outta commision.
Need a new pipe.
Emirates Hobbies
Support your LHS.!
       Post #: 10
RE: Put revs on and truggy went backwards???? - 1/5/2008 2:07:46 PM
ttoks
Status: offline
it won't mess up your clutch, i run my clutch backwards normally, holds up just fine..
but the engine doesn't breath properly running backwards because of the timing window in the crankshaft, doesn't match up properly running backwards.
(in reply to qaiz)
       Post #: 11
RE: Put revs on and truggy went backwards???? - 1/5/2008 2:13:40 PM
qaiz
Status: offline
I cant run till the new pipe gets here
Theres a major crack in my existing pipe, and my header has an air leak.
My JP 4 should be here by next week hopefully
Emirates Hobbies
Support your LHS.!
(in reply to ttoks)
       Post #: 12
RE: Put revs on and truggy went backwards???? - 1/5/2008 2:52:18 PM
zs123
Status: offline
yeah but after i started it agaim im ran fine and iam use a pullstart lol sooo iam stoll stuck??
(in reply to qaiz)
       Post #: 13
RE: Put revs on and truggy went backwards???? - 1/5/2008 2:55:19 PM
qaiz
Status: offline
I didnt quite get the question.
Is it running normally (forwards) or is it still going backwards.?
Emirates Hobbies
Support your LHS.!
(in reply to zs123)
       Post #: 14
RE: Put revs on and truggy went backwards???? - 1/5/2008 3:58:11 PM
zs123
Status: offline
its running forward but sometimes when i start it it still goes back
(in reply to qaiz)
       Post #: 15
RE: Put revs on and truggy went backwards???? - 1/5/2008 4:19:16 PM
ravenlunatic
Status: offline
i'm getting a good laugh thinking about the looks on people's faces when they're set to go and they gun it and the truggy shoots backwards!
v-one-s, picco powered savage X ss, TT-01, BL xxx-s, hyper7, AX10
(in reply to zs123)
