bikeracer
Joined: 7/8/2006 From: , UNITED KINGDOM Status: offline
quote:
ORIGINAL: splcrazy im worried if i threadlock the bolts i wont be able to get them out again , is there special kind of thread lock glue that isnt super strong ? also where can i get a engine rebuild kit for this motor for spare parts, i couldnt find nitro engine rebuild kits on the 2wheelhobby site . also i want to go for a tread tire , are those tires displayed on 2wheelhobbies is it one size fits all? because there is differnt brands i know that the front and rear tires are differnt size , do i have to stick with the thunder tiger tires , there is no information on that site to tell you for eg: this tire set is suitable for the desmosesdici or other lol so i dont have a clue what tire i need to get when they wear out . Use the blue threadlock.The front and rear tyres will fit whatever make you buy. The engine is a TT,so all you'll need is a TT spares list.The engine in a bike doesn't have such a hard life as in a car so should last you a while.If you use an electric drill for starting you could well crack the OWB inside,so be prepared to buy spares.An aircraft starter is a better choice and will spin the engine faster as well. .
