MYHELIGUY
use the string used for bow fishing,its about the strongest you'll find. cut about 12 inch long piece,hang it up,coat it with ca glue,dry real good,cut it to the length's you need for hinges,drill a hole in the coroplast where you want hinge,both pieces,glue the ca string in the holes,do all the preferred hinges holes string at the same time,let dry,slowly bend the elevator or aileron,the ca glue will flex off,and you possibly have the best strongest hinges.and very light weight.you can use larger diameter string for larger hinge making.
