RE: What is your opinion on RedCat?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: What is your opinion on RedCat?
Page: <<   < prev  1 2 [3]
Login
RE: What is your opinion on RedCat? - 1/8/2008 3:36 AM
pede_187
Score: 100
Last Login: 8/10/2012
Status: offline
I had the same consern as you at first. Run it rich at first. After a while, you will get to know the engine and actually what it will sound like when tuned correctly.
Hide Signatures
(in reply to ehroof)
       Post #: 51
RE: What is your opinion on RedCat? - 1/8/2008 3:47 AM
S.R.G.
Score: 100
Last Login: 6/19/2011
Status: offline
Yea, I am going to follow the manual needle settings I guess, unless you believe the factory setting should be fine. Below are the manuals needle settings, please tell me if these should be correct for a rich mixture or not.
"Make sure your engine is set for break in. Close the high-speed needle until
its snug. Turn the high-speed needle counterclockwise 3 full turns. Close the
low speed needle and open until the throttle until it is even with the silver
collar around it."
Thanks.
Hide Signatures
(in reply to pede_187)
       Post #: 52
RE: What is your opinion on RedCat? - 1/8/2008 3:58 AM
xjedix
Score: 100
Last Login: 5/6/2008
Status: offline
Yes, that is the correct settings for break in. When they use the term "snug" that means until you feel a little resistance; do not torque them down too much. As long as you see blue smoke then you are in the safe zone.
_____________________________
Derek Hastings - Affordable RC - affordablerc@gmail.com
Hide Signatures
(in reply to S.R.G.)
       Post #: 53
RE: What is your opinion on RedCat? - 1/8/2008 4:03 AM
S.R.G.
Score: 100
Status: offline
Thanks. Also, with the gear placment - use a pice of paper to test their position? Does this mean put the paper around the gear - as in the manual - and push the gears together snug or with pressure (pushed hard)? I am needing to make sure and this should end all of my questions hopefully until I get down to running my new rc (finally and end to the long rampage).
"Check the mesh of your spur gear and clutchbell. Take a small piece of
paper, cut it into a ½ inch wide by 6 in long strip as shown below. Loosen the
4 engine screws on the bottom of the car as shown above so the engine slides
back and forth. Once you have the engine screws loose put the piece of paper
between the clutch bell and spur gear. Push the engine into the spur gear and
tighten the engine bolts. Pull the paper out and you are done."
Leaves me blank on the force to push them together.
Thanks.
Hide Signatures
(in reply to xjedix)
       Post #: 54
RE: What is your opinion on RedCat? - 1/8/2008 4:14 AM
pede_187
Score: 100
Status: offline
I usually push it together with force but after you do that, roll the car to make sure it meshed correctly.
Hide Signatures
       Post #: 55
RE: What is your opinion on RedCat? - 1/8/2008 4:33 AM
S.R.G.
Score: 100
Status: offline
And look/feel/listen for? - any more opinions on the force to be applied when using a piece of paper to check gear placement?
Hide Signatures
       Post #: 56
RE: What is your opinion on RedCat? - 1/8/2008 5:08 AM
pede_187
Score: 100
Status: offline
Just push together. Not with A LOT of force.
Hide Signatures
       Post #: 57
RE: What is your opinion on RedCat? - 1/8/2008 5:21 AM
S.R.G.
Score: 100
Status: offline
Got ya. Sounds good, cannot wait to get it in.
Hide Signatures
       Post #: 58
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.312RCU1
