ct420
TX, USA Status: offline
There are different types of balancers that use different concepts. I don't have a blinky myself, but I do have something similar. I am pretty sure the Blinky is a 'stand-alone' balancer only. Meaning, you do not connect it between the charger and the battery so it can limit the charge to any particular cell. With the blinky, just connect it to the battery before charging. It should reduce the voltage over every cell in the pack to match the cell with the lowest voltage. In your case, all cells should end up at around 3.14v. Once it's finished, remove it and connect the pack to your charger and charge it up. Yes, it should be OK to leave it connected for days without any problem. It is OK if it gets a little warm, but should never get 'Hot' feeling at all. Again, I don't have a Blinky, so I can't say for sure how warm it will get, but I know my LBA6 does get a little warm when balancing a badly unbalanced pack. Probably not more than 100F though, if that....
