efish
Joined: 8/12/2005 From: Singapore, SINGAPORE Status: offline
Hi, I'm having some problems setting up a 65.5" wingspan Extra 330. No specs from the manufacturer, but I approximate the wing area at about 900 sq inches by pure guess work. The plane has airfoiled rear stabs, elevators and rudder. Think I read somewhere that an airfoiled horizontal stab had the effect of increasing the effective wing area and allowed the use of a more rearward CG. I first flew the plane with a 26cc gas engine that seemed to balance the plane nicely with 2 batts in the engine box. AUW was about 9 lbs. Power, take off and general flying was no problem, however, I found that the wing loading seemed to be all but destroyed - all was well above about 1/3 throttle, but below that, the plane would tip stall unpredictably. Landings had to be hot otherwise the plane would just seem to quit flying. Thrust line tests both in level flight and on vertical lines showed the factory setting to be reasonably close. At this point, the CG was setup just behind 1/3 of the root rib chord. Even then, it took quite a bit of up elevator trim just to hold level flight. Rolling inverted while climbing at a 45 degree angle, the plane would hold the climb before gradually pitching towards the ground. My theory was that the gas engine was too heavy and that I needed to lighten up the AUW. I have on hand a FZ-110 that puts out more power than the gas engine but weighs about a lb less. As I type this post now, I'm reconsidering - could it be that I had the plane too TAIL heavy even with the gas engine? - that would account for the seemingly optimum results during the inverted 45 degree climb test but wouldn't explain the up elevator trim needed for level flight. With the YS, the plane seems rather tail heavy - CG is about middle of the root rib, so I'm loathe to risk the plane by flying like that. I generally like my CG towards the tail, but this plane is something of an unknown and doesn't appear too forgiving so far! And correcting the CG by adding weight would negate the benefits of using a lighter engine. Would have thrown in the towel, except that the plane flies decently at speed and does show some promise. Besides, I'm hoping to salvage some of the considerable time and expense I've already put into the plane. Does anyone have any suggestions/theories? Thank you.
