Why add all the CX2 aluminum parts???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Why add all the CX2 aluminum parts???
Page: [1]
Login
Why add all the CX2 aluminum parts??? - 1/8/2008 12:31 AM
RMG2
Score: 133
Last Login: 10/5/2010
Status: offline
I'm having a hard time understanding why so many CX2 owners add all the aftermarket aluminum parts to their helis??? I can understand replacing stock plastic parts with aluminum where chronic breakage occurs, but adding aluminum just for the "bling" factor adds unnecessary weight. The only advantage added weight might have for a CX2 is in hover stability, but in every other flight aspect added weight will kill performance!
I saw this same thing happen a lot racing Monster Truck class in the RC Pro Series. Guys would put all the aluminum stuff on their trucks and then wonder why their trucks were slow, handled badly, jumped badly, and burned-up clutches and engines
For our CX2 helis more weight equals less run time, greater chance of blade clack under heavy wing/blade loading, slugish performance, more expense in both aftermarket parts, and repairs after crashes. Remember, plastic gives a little under stress, and because of that will often take more abuse then will an aluminum replacement part. Also, if you add rigidity to one part, then the load, or crash stress goes to the next part in connection with the rigid part. When those aluminum swashplates don't give a little under load, or crash stress where is the stress energy going? That's right, it's going into the more-expensive-to-replace servo! Think about it???
In my humble opinion, the best compromise for performance and durability for our CX2's is a blend of NECESSARY (for strength) aluminum, and stock plastic parts.
Of course, if you are just wanting to build a "shelf queen" then by all means add all the "bling" you can get for your heli
Hide Signatures
       Post #: 1
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 12:37 AM
seanreit
Score: 100
Last Login: 4/26/2010
Status: offline
Ok, then in your opinion, which parts should be upgraded to aluminum?
Hide Signatures
(in reply to RMG2)
       Post #: 2
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 12:39 AM
stump3r
Score: 100
Last Login: 4/2/2013
Status: offline
RMG your bang on with your comments. The large majority of us that have all CNC birds do one major thing to counter the weight. We all run the Xtreme 180 motors, silver brushes and all of us have higher rated lipos. I personally have been a little rough with my CX2 and with the exception of the airframe, servos and swash I have broken, bent and otherwise destroyed every part of the heli. I upgraded to all aluminum, saves a ton on plastic parts. The only real kicker with CNC rotor hubs is instead of shearing the blade pins, now it bends shafts. One huge upgrade regardless of weight is blade grips, they are a shaft saver! Since moving to the Xtreme grips I have only had to replace 1 outer and 1 inner shaft, and the reality of that is silk plants in the living room can destroy a heli quicker than flying into a brick wall.
_____________________________
MSR, Gaui 200SD, 200EX, 200SEV2 255, CX500SE, DX7
Hide Signatures
(in reply to RMG2)
       Post #: 3
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 12:51 AM
RMG2
Score: 133
Status: offline
quote:
ORIGINAL: seanreit
That's an easy answer. Which ever part(s) you consistently have breakage problems with. Or put another way, I would run the lightest weight parts I can and have a reliable heli.
Not trying to step on any manuf. toes, but not all after-market parts are necessary, are an improvement, or are even more functional. This statement applies to every machine in our lives, not just RC.
The point of this post is simply to let all the new CX2 users know that they don't need to rush out and buy all this after-market stuff to have a well flying heli. It's nice to have options, but the last thing a new RC heli owner should be worred about is upgrades to his/her heli.
Just my opinion, we all have one
Hide Signatures
(in reply to seanreit)
       Post #: 4
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 12:56 AM
goldslinger
Score: 100
Last Login: 9/14/2009
Status: offline
I agree with Both of You.
Mine is completely aluminum and is only 4.5 Grams heavier than stock. But that is because I went into it with the mindset of not just looks, but durability.
Not only is it virtually indestructible, it is light and agile as I have countered the weight with strong, but light materials with C.F. outer and Titanium Inner, C.F. BOOM, C.F. flybar, etc.
So in my case, it's not just looks, but durability. If they made C.F. grips, I would buy those instead.
I agree that If You overdo it, You will shorten the life of the motors, batteries get hotter, flight times are shortened, the gears wear out sooner, etc.
I am running 22c batteries, not because of the added weight, but I like the added agility and I crash less because the power is there when I need it, esp. at the end.
Alot of people by now have gone full circle, and I don't think there's nothing wrong with the stock swash, and if You have the XTREME motors, You could lose the heat sinks. Just monitor the motor temps, that's all.
" No Excuse for My Failures; No apologies for My Success."
_____________________________________________
Hide Signatures
(in reply to stump3r)
       Post #: 5
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 1:25 PM
Vistralan
Score: 100
Last Login: 4/22/2010
Status: offline
Goldslinger, are you working on an indestructible Trex 450 SE v2 yet? reason I ask is I know you just got one and that is what I'm looking to move up to in a few months =)
Hide Signatures
(in reply to goldslinger)
       Post #: 6
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 7:08 PM
goldslinger
Score: 100
Status: offline
quote:
ORIGINAL: Vistralan
Good Choice !
The price upfront makes people hesitate, but replacement parts are cheap, and You won't find an easier CCPM heli to learn to fly because of it's quality and therefore, inherent stability.
I think the T-REX will be the tinkerer's dream, tweaking this and that, but as far as upgrades; it is so near perfect; I don't know how in the world I could improve it. The consequences of experimentation on a 3k head speed heli could be dire.
Mine is coming with all aluminum and metal geared servos, digital tail rotor servo, etc. already.
Hide Signatures
(in reply to Vistralan)
       Post #: 7
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 7:56 PM
The Hedgehog
Score: 275
Last Login: 5/24/2013
Status: offline
I was going to make a thread on this tomorrow ha! I see some of these CX's so blinged out and wondering why, aside if it is a shelf queen. I agree I guess some things can be done to make the bird more stable but I found it very easy out of the box, so easy I got bored with it within a week.
Are you guys breaking a lot of parts on your CX's?
Sorry for being ignorant I was just thinking about this and wondering how effective the aluminum is when you can put the money towards more batteries or something of that nature.
What would Chuck Finley do?
Hide Signatures
       Post #: 8
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 8:18 PM
notasme
Score: 100
Last Login: 3/1/2009
Status: offline
RMG2
I agree with you and I have said similar in other CX2 posts.
This bird is as entry level as it gets (today). Mods only complicate
this for those just starting out.
notasme
Hide Signatures
(in reply to RMG2)
       Post #: 9
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 8:32 PM
t9dragon
Score: 328
Last Login: 5/23/2013
Status: offline
I added the aluminum and after market upgrades to add some weight to my CX2. So that when flying outside it wouldn't be tossed around by the slightest breeze.
< Message edited by t9dragon -- 1/8/2008 9:11 PM >
Hide Signatures
(in reply to notasme)
       Post #: 10
RE: Why add all the CX2 aluminum parts??? - 1/8/2008 9:11 PM
BryFlyGuy67
Score: 100
Last Login: 3/6/2009
Status: offline
Some of the mods are purely cosmetic in nature, whereas others truly help you. Here are a few that come to mind:
1. Unbreakable / super skids
2. CF tail boom
3. Extra, higher "C" rating batteries
TREX 450 V2 (BLK), CC35, 12T; NEU 1107/2Y
TREX 450 V2 (SLVR), CC45, 14T; NEU 1107/2Y
Hide Signatures
(in reply to t9dragon)
       Post #: 11
RE: Why add all the CX2 aluminum parts??? - 1/9/2008 5:23 AM
stinknugget
Score: 100
Last Login: 11/2/2012
Status: offline
Im slowly starting to get the bug for a heavier heli for outside. Using the proper setup you could have everything aluminum and stil have great flight characteristics as well as a decent flight time. My first and current heli is alll plastic except for the upper and lower rotor heads, the upper is stock now and the lower is the microheli which is by far better than the eflight. I believe i am going to start building an all aluminum and carbon fiber cx2 from scratch soon as i am getting pretty good at flying this one. Anyway you cut it, have fun!
Hide Signatures
(in reply to BryFlyGuy67)
       Post #: 12
RE: Why add all the CX2 aluminum parts??? - 1/9/2008 5:37 AM
stump3r
Score: 100
Status: offline
Bry, don't forget blade grips and better blades. I would have never been able to afford my #4 without changing blades on my heli.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.688RCU1
