daven
MN, USA Status: offline
For 424, just leave the "sponsored by dremel" stickers off the nose There are enough paranoid people out there that think racing is ruled by cheaters, the sad part is, its not normally the winners that cheat. Its those that chasing the winners. Its ok to modify shims in the NCPL, but not everywhere. If your running no head shim, you better make sure the plug is going to clear the piston, and you get the head bolts evenly torqued.
_____________________________
Dave Norman klasskote.com supertrc.com
