RE: Magic VF3 building thread
Tower Hobbies
Logged in as Guest
  Printable Version
WILD THING 40 SUMMER SALE - Kit
Seller:  THOR-RCU
Details:   $55.00   |  8/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> TEAM RCU >> Team RCU - Don Szczur >> RE: Magic VF3 building thread
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Magic VF3 building thread - 1/29/2008 1:00:40 AM
scratchbuildC
Status: offline
don great thread ,are their plans for the vf3. I like to build one.
(in reply to Don Szczur)
       Post #: 26
RE: Magic VF3 building thread - 1/29/2008 4:56:05 AM
Don Szczur
Status: offline
Hello Verne. You can get the details on the kits at www.customairframes.com.
A quick wing tube check was fruitless. The wing tube is perfectly aligned and perpendicular to the centerline with no adjustments necessary. The laser cut fuselage sides were perfectly aligned.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to scratchbuildC)
       Post #: 27
RE: Magic VF3 building thread - 1/29/2008 4:58:34 AM
Don Szczur
Status: offline
Next was the top forward former, carbon/ply brace, and then the diagonal braces installed.
Click for fullsize
Click for fullsize
       Post #: 28
RE: Magic VF3 building thread - 2/2/2008 5:01:52 PM
Don Szczur
Status: offline
Installing wing adjusters.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 29
RE: Magic VF3 building thread - 2/2/2008 5:08:01 PM
Don Szczur
Status: offline
Install center top bulkheads and little cross piece, top stringers, sides. Note the sides are cut at different length, a right and a left. Trial fit them, mark and notch a slot for the stringer to go through the back bulhead.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 30
RE: Magic VF3 building thread - 2/2/2008 5:13:23 PM
Don Szczur
Status: offline
Trial fit the back deck, notching the foam so the stringer goes through. This keeps the back deck aligned with the fuselage sides. Glue the back deck in place. Everything fit perfectly. I put pins in after taping to give the top deck recessed about 1/32 inch. That will allow for sanding to a blended joint between the top deck and fuselage side.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 31
RE: Magic VF3 building thread - 2/3/2008 3:21:05 AM
Don Szczur
Status: offline
Tape canopy base plate. Glue back one in place (sand bevel at bottom so it fits perfectly) Put on top piece, put on front piece, glue top piece in, glue front piece in. Glue front bulkhead. Mark where back Violett slide mount fits. Drill through both canopy back piece and bulkhead. I used inner pushrod which fit well if drilled slightly .
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 32
RE: Magic VF3 building thread - 2/5/2008 8:57:36 AM
Don Szczur
Status: offline
Front deck sheeting strips. This process took very little time. Most strips required no sanding to fit. Re-trimmed twice with a straight edge to true the strips as it wound around the top.
Click for fullsize
Click for fullsize
       Post #: 33
RE: Magic VF3 building thread - 2/7/2008 5:18:39 AM
Don Szczur
Status: offline
Sand and trim front sheeting. Sand and countour back sheeting with back former. Sand canopy frame so its about 1/16 inch smaller than the front and back formers. Sand and rough up the gluing surface of the canopy inside mating surfaces. Use a straight block to set the canopy on while the glue sets. Trim the edges of the canopy. Canopy mounted-
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 34
RE: Magic VF3 building thread - 2/7/2008 10:46:41 PM
Scott Smith
Status: offline
Hi Don,
Have you figured out where these pieces go? I know they are supports for the upper turtle deck former but I can't figure out their exact location!
Click for fullsize
       Post #: 35
RE: Magic VF3 building thread - 2/8/2008 4:03:02 AM
Don Szczur
Status: offline
Here c/o Don
Click for fullsize
Click for fullsize
(in reply to Scott Smith)
       Post #: 36
RE: Magic VF3 building thread - 2/8/2008 4:05:14 AM
Don Szczur
Status: offline
And here for the triangles you circled.
